front brakes lock easily when its cold outside
just like the title says. I know I need a booster and one side the rotor wasnt turned by the p.o. and now has a notch in it.
Re: front brakes lock easily when its cold outside
Mine did the same thing. I just ended up replacing my rotors, calipers and pads to fix it. Also, I flushed my brake fluid.
What I suspect is that one of the calipers is sticking slightly.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
possible you have water in lines?
Thread Tools | |
Display Modes | |
