Old 11-14-2012, 05:52 PM   #1
JJAB
Injector Size?
I have performed four basic LS swaps. Only one did I cam. I am thinking of stroking a 6.0 truck block to a 408 or 416. No turbo or supercharger. If I am not adding a power adder that requires more fuel, will I have to increase my injector size from stock?
JJAB is offline   Reply With Quote
Old 11-15-2012, 09:25 AM   #2
whitels1
whitels1's Avatar
Re: Injector Size?
I would say no, but your tuner will let you know if you are getting close to maxing out your injectors.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 11-15-2012, 12:26 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Injector Size?
The stock truck injectors are pretty small and use most of their duty cycle to fuel the truck as is. I' suggest something like the 39 lb/hr Ford injectors; including the clips they don't cost most than $150 or so.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-16-2012, 12:17 AM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Injector Size?
my tuner provided my efi setup. the injectors he gave me for a 500+hp setup are 50# Chrysler injectors...with room to grow.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-16-2012, 11:56 AM   #5
Custom 68
Custom 68's Avatar
Re: Injector Size?
I probably would too, another option is either "stock" 8.1 truck injectors or "8.1 Marine" injectors. The marine injectors flow more. These are both plug and play with the truck harness and truck intake. I used them before I went turbo. They give a little wiggle room.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-16-2012, 06:50 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Injector Size?
imo a cost of marine injectors is a chunk more than ev1/ev6 injectors and plugs for them. If you outrun the marine injectors, you have to have custom flowed ones made...whereas if you switch to ev1/ev6 plugs you have more options, cheaper and more available.
Old 11-19-2012, 11:11 AM   #7
JJAB
Re: Injector Size?
Gentlemen, I really appreciate all of the information. You have given me a good foundation of information to make a decision from. Again, my plans are for a 408 or 416 LS, no turbo or supercharger. So, I just want to make an educated decision.
Old 11-19-2012, 11:22 AM   #8
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Injector Size?
You can pick up the Siemens 60 lb/hr for a good deal, used. That will give you room to grow if you do go with a power adder down the road (including a dry nitrous setup) or E85. Not necessary, but an option if you're going to buy injectors anyway.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-26-2012, 05:41 PM   #9
hoover
Re: Injector Size?
ls6 intake and injectors fit on 05, 6.0 engine? thanks
hoover is offline   Reply With Quote
Old 11-27-2012, 12:26 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Injector Size?
You might want to spend some time searching through the FAQ and the various builds, as well as spending some time over @ ls1tech.
Short answer is yes...but you have to change to the car front drive accessories. You'd also have to get the fuel rail with it as well, and run the vette-style returnless fuel filter setup.
You also need to change the wiring harness at the injector clips, from the truck MultecII injector clips to the EV1 clips. There really is no gain to running stock ls6 injectors, you'll still outpace them, they are only 28lb injectors.
Thread Tools
Display Modes
