1 1/4" Sway Bar
SOLD! This is the beefy one. It comes with the frame brackets and bushing retainers. It could use new rubber and you will need grade 8 bolts. $60 plus shipping. Shipping could be around $30 to the east coast. Post office money order please.
Thanks, Ray Last edited by KrazyRay; 12-15-2012 at 12:47 AM. |
Re: 1 1/4" Sway Bar
Ray,
How much shipped to 58012? Thanks, Ryan |
Re: 1 1/4" Sway Bar
Its $27 to ship to ND.
Re: 1 1/4" Sway Bar
Thanks for getting back to me so quick. I'll take it!
Thanks, Ryan |
Re: 1 1/4" Sway Bar
pm sent
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: 1 1/4" Sway Bar
That 'll be the best bang for the buck $77.00 you spend on your truck. You'll feel the difference right away after the sway bar is installed.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: 1 1/4" Sway Bar
I sure hope so! Now I gotta find a rear sway bar to make everything come together!
Posted via Mobile Device |
Re: 1 1/4" Sway Bar
I wonder if this one would fit? It came from a 74 Chevy truck option RPO Z83
Re: 1 1/4" Sway Bar
i bought CPP sway bars for my 72 Burb C20, but think I might have gone this route if I'd known about it 3 years ago. The big bar is from a 73-87 1 ton or camper special, from what I hear.
And it would be cool to find a good size factory GM rear bar that would fit on our trucks with trailing arms instead of leaf springs. So whoever tries that rear bar out needs to let us all know.... |
Re: 1 1/4" Sway Bar
How big is that rear bar Ray? I've heard you want 70-80 % of the front. I'll try to do some checking on this to make sure this would fit. Hopefully someone sees it that has done that to let us know. How much would you want for it?
Thanks, Ryan Posted via Mobile Device |
Re: 1 1/4" Sway Bar
Hope ya dont mind me posting this Ebay link for a rear sway bar.
http://www.ebay.com/itm/300682156674...84.m1423.l2649
Re: 1 1/4" Sway Bar
I would much rather have a factory sway bar and I think that bar would be too thick...
#13 |
Re: 1 1/4" Sway Bar
This factory rear sway bar came from the same truck that the front one you are buying came from so it should be porportionally correct. I measured the frame on a 70 3/4 ton and its about 31 1/2" in between the frame rails where the sway bar mounts and its 31 1/2" center to center on the sway bar ends. Its very close to fitting with no mods.
#14 |
Grandpa in the rustmobile...
Re: 1 1/4" Sway Bar
I can do $60 shipped to 37357, dont have paypal you would have to wait for a letter int he mail.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#15 |
Re: 1 1/4" Sway Bar
#16 |
Re: 1 1/4" Sway Bar
Hey thanks for doing that! It really shouldn't matter if the truck that you took it from was leaf springs and mine is coil should it?? Do you know the thickness of this bar?
#17 |
Re: 1 1/4" Sway Bar
The bar is 1 1/16". It uses the factory round u bolts on the 74. I would think you could use round u bolts going around the bottom of the axle and then use the round u bolt brackets on the top since there is no leaf on top or you can fab up your own bracket.
#18 |
Re: 1 1/4" Sway Bar
Okay, how much are you asking for this one?
#19 |
Re: 1 1/4" Sway Bar
Wasnt able to get to the post office today, I'll let you know when I get the $ sent out.
#20 |
Re: 1 1/4" Sway Bar
#21 |
Re: 1 1/4" Sway Bar
#22 |
Re: 1 1/4" Sway Bar
Is that price for both front and rear? So it would be 150 total?
#23 |
Re: 1 1/4" Sway Bar
Im claiming the front bar. Need to get to the post office next day or 2
#24 |
Re: 1 1/4" Sway Bar
To avoid confusion, I have 2 bars. The one with pics posted in this thread is going to Ryan and I have a loose one without brackets going to John. The bars are identical, but I will post a pic of the 2nd bar.
Thanks, Ray |
#25 |
Re: 1 1/4" Sway Bar
I thought the big bar was the one in the first post with brackets?
Thread Tools | |
Display Modes | |
