Old 11-19-2012, 11:49 AM   #1
blazer2007
bracing for new floor ?
Getting ready to bring out the cut off tools on a 78 Blazer to notch a crossmember and put in some new floor where needed,mostly the back end and the sunken floor behind the dr.and pass. seats.I never thought about bracing until I read a thread on paint section.Was wondering if anyone had some input on where to brace as a Blazer would have different bracing points than a truck
blazer2007 is offline   Reply With Quote
Old 11-21-2012, 04:03 PM   #2
UKNOWME
UKNOWME's Avatar
Re: bracing for new floor ?
Are you using patch panels or did you find full sections? I need to replace the floor on my 78 from the firewall to the step up, both sides. No idea on the bracing question though
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 11-21-2012, 04:05 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
I haven't read that thread about bracing but sounds like a good idea. Maybe two front/two rear on the same rib, per side? Three or four inch gussets like you would use on roll cage?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-22-2012, 11:20 AM   #4
blazer2007
patch panels,mostly dr. side corners,back end and step section
Thread Tools
Display Modes
