Old 11-26-2012, 04:02 PM   #1
slimbailess
slimbailess's Avatar
64 C-10 radiator mounts
need some help, building my first truck from this era, and out of three trucks, I don't have anything that I know is the upper bracket for the radiator...have seen a few brackets in pictures, but no good pictures...I think it is a clamp that bolts in and covers the top tank of the radiator, but I need some good pictures, and/or some measurements....I am going back home this week, and looking forward to getting my 64 on the road...any help will be greatly appreciated!!! also, if anuone has a link on a vendor that sells it or has a page showing the proper name that would help too...thanks, Slim
slimbailess is offline   Reply With Quote
Old 11-26-2012, 09:17 PM   #2
McCoyAZ
McCoyAZ's Avatar
Re: 64 C-10 radiator mounts
looks like this
64 65 66 chevy truck radiator holddown
McCoyAZ is offline   Reply With Quote
Old 11-26-2012, 09:28 PM   #3
brap999
brap999's Avatar
Mine was missing on my truck too. I just welded together one with strips of metal from a local hardware store. If you know how to weld, Just get your radiator in place, and take measurements and build your own. Don't forget to take into account the thickness of the rubber that goes between them and the radiator. I forgot to take that into account on the first attempt, and ended up having to build it all over again.
As far as I am aware no one reproduces them, so you'd either have to build your own, or find a used one.
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
Old 11-26-2012, 10:13 PM   #4
slimbailess
thanks for the picture and the info...welding and fabbing are no problem, just needed an example for a pattern....
Old 11-27-2012, 12:43 AM   #5
Captainfab
60-66 Nut
Are you running the smaller 6 cyl radiator or the larger radiator typical for V8's? Is it a 3 row core or a 4 row core? I believe I have all 3 if you would rather buy one, than spend your time fabricating one.
Old 06-11-2015, 01:32 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
How do you know if it is 6 cylinder or a V8 upper bracket? I have a bracket but I don't know.
Old 06-11-2015, 01:51 PM   #7
1963c-10
1963c-10's Avatar
The 6cyl bracket runs straight across....the v8 bracket is pictured above in post 2.
Pic attached is the 6cyl bracket (borrowed from the classifieds)
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Thread Tools
Display Modes
