12-01-2012, 12:36 AM | #1 |
72, water on floor board, from?
ok, I had the truck since summer and now that it is raining pretty darn good I noticed the passenger side floor was wet. I know I have a new window and window seal on the front and door trim seals. so my question is, where are the possible locations and or places on the cab that will leak... where do I start looking
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
12-01-2012, 12:41 AM | #2 |
Re: 72, water on floor board, from?
i think you may have answered your own question. Before I read the second half of your thread, I was going to guess the window seal. Then when I read you just had the window+seal replaced, that kind of seals the deal (no pun intended). if you paid a shop, take it back and have them re-do, even though a pain in the butt. Possibly lower passenger side of windhsield seal leaking.
12-01-2012, 12:44 AM | #3 |
Junior Member
Underneath the cowl there are quite a few areas where there are sealant where parts come together. Over the years this sealant will harden and crack.
Also water can come in around the windshield wiper motor shaft under the cowl. These are just a few areas, hopefully others will add more info.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
12-01-2012, 12:46 AM | #4 |
I know its not the window or seal. replaced in summer, numerous wash jobs and no leaks..... I will look undedr the cowl and surounding areas
12-01-2012, 12:56 AM | #5 |
Maybe the antenna cable hole in the cab
Cowl vent drain clogged with leaves
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
12-01-2012, 01:11 AM | #6 |
I know my truck personally does this only when I take it through the car wash. I end up with a pool of water on the passenger side floor mat. On my truck it is a hole in the cowl that drops straight down into the passenger floor. It's not big but you notice it when you pressure wash it. Try on a sunny day looking up from your passenger side floorboard you will see where the water is coming from.Must be a Chevy thing.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
12-01-2012, 01:17 AM | #7 |
What?
Check the antenna cable, and where it comes in from the outside.
Have seen it where the water will follow the cable, and drip where the cable droops the lowest. Usually right where the passengers feet would be. Take some silicone and seal the hole where the cable comes through.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-01-2012, 02:26 AM | #8 |
Ah, sorry, I kinda read your thread thinking you replaced them and then, all of a sudden, a leak... If lots of water exposure and no problems, then no, probably good there. Once a new seal is proven good, it'll be good a long time probably. Sorry bout the confusion.
12-01-2012, 02:34 AM | #9 |
VA72C10
I agree on the inner cowl being suspect #1. My 67 had a spot where the sealer was out and leaked onto the passenger floorboard.
Looking for a 67-72 swb or blazer project in or around VA. |
12-01-2012, 05:44 AM | #10 |
When mine leaked it was through the hole for the antenna wire. There is a rubber gromit that fits into this hole and allows the wire to run through it. I popped the gromit back into the hole and haven'tad a problem since.
12-01-2012, 10:11 AM | #11 | |
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
12-01-2012, 10:39 AM | #12 |
Old Skool Club
So, your kick panels are rust-free? Is there no dirt/trash accumulated in the base of that panel, like just inside the vents?
The previous owner of my truck was trying to find the source of similar leaks to your and used the wrong silicone sealer and created a swiss-cheesed firewall, along with a lackametal around the wiper motor....which fell out one morning....in the rain. So, after you take the plenum grille off from in front of the windshield, you'll have better views.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-01-2012, 11:54 AM | #13 |
Possibly your heater core?
Cheers - Wayne Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966 '55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157 1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy" 1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55 Nothing sucks more than that moment during an argument when you realize you're wrong. |
12-01-2012, 12:23 PM | #14 |
check your drip rail sealant above the windshield. If its old and cracked that could be a problem also.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
12-01-2012, 12:35 PM | #15 | |
12-01-2012, 12:46 PM | #16 |
i will pull her in the garage today and take a look....... thanks all for the possibles
10-29-2014, 11:13 PM | #17 |
I have a second 72 chevy a lwb. Recently my daily driver was hit by a ford
and totaled out a 2003 chevy truck no notes. I had to start driving the old chevy daily. When it rained water fell right on my left foot and I noticed the passenger side the same. I have read the replies and tore all that applies apart,I find one part not mentioned. The channel that holds the electricals for starter engine temp etc held on by 3 5/16 screws need to be pulled and sealed it has factory sealant inside front on that channel with a seam all the way across the cowling area. I"ve done that it is suppose to rain here in tx tomorrow I will find out first hand and post a reply to this one. Before u mention it I know I could run the water hose. If there is no rain I will. |
10-29-2014, 11:46 PM | #18 |
10-29-2014, 11:55 PM | #19 |
Mine has a rust hole behind the glove box. It leaks on top of the AC box and then drips on the floor.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored 1978 Turbo Malibu - Owned since 1986 1987 Grand National Aerocoupe -1 of 1 1988 LeSabre T-Type - Supercharged |
10-30-2014, 10:23 PM | #20 |
I already have a new core. I will install it before it gets to cold will keep
u posted on progress. |
10-31-2014, 09:06 AM | #21 |
Thats what I was going to suggest, does the water smell clean, or like antifreeze? I would suggest just running it inside the garage/shop for a bit out of the rain and see if it is leaking. If not, then you have a seal issue with the oitside world
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
10-31-2014, 09:13 AM | #22 |
Oh, one other siggestion, is it carpet? If so you may want to look for a small hole in the foor pan, the carpet will wic the water over a larger area making it seemblike its a big leak, when its actually an old screw hole in the floor pan.... seen that befor first hand.
10-31-2014, 09:15 AM | #23 |
Damnit!! Who revived this 2 year old thread....... I totally fell for it.... wha wha wha
Thread Tools | |
Display Modes | |
