Old 12-02-2012, 07:26 PM   #1
gmcdeadhead
gmcdeadhead's Avatar
late model rims
has any one put these late model truck rims on a 1960-1966 truck? if so how did they fit? were they to far in or to far out , i'm looking to buy a set and run 265/75/r16 tires on them. any help would be great , the truck has stock front and rear end , but it will get the 73-87 front and rear conversion done within the year . thanks , [IMG][/IMG]
gmcdeadhead is offline   Reply With Quote
Old 12-03-2012, 10:00 AM   #2
kieth
kieth's Avatar
Re: late model rims
I have seen another 3/4 ton with those wheels somewhere, check to see what your stock wheels are now from the face of the wheel to the outer edge of the rim, then do the same for the inside offset. I thinks they will work just fine if your truck is setting at a stock height. I currently run 265-70-17 on 9" wide cragars in the rear and they are fine (but it is close due to the offset) since the wheels your are looking at do not have much offset they should work fine on the rear axle.
I run 9" wide 17" Cragars on the front and my truck is lowered so we used a smaller front tire to allow clearance...I think they are 255-65-17" again with normal spring heights on a 3/4 ton you should be ok. Kieth
ps when you do your front conversion be sure and get the 3/4 ton front crossmember, ps pump, sway bar, they are different than a 1/2 ton front end.....
kieth is offline   Reply With Quote
Old 12-03-2012, 10:45 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: late model rims
You mean like this? IIRC, only thing is the hub caps had to b e these larger ones to fit over the hub, the chassis is a 72 GMC so you know.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-03-2012, 11:11 AM   #4
gmcdeadhead
Re: late model rims
i have the original 17.5 rims on there now , i'm going to do the 73-87 front end and rear end conversion sometime within the year , so you think those rims will work on my stock truck and the conversions i'm going to do? heres my truck[IMG][/IMG]
Old 12-03-2012, 09:08 PM   #5
DoubleL
DoubleL's Avatar
Re: late model rims
I am running these right now with 265/75/16s. I think they are late 80's to late 90's.
My 1965 C-20 project
https://67-72chevytrucks.com/vboard/...d.php?t=835095
DoubleL is offline   Reply With Quote
Old 12-03-2012, 10:23 PM   #6
Clyde65
Clyde65's Avatar
Re: late model rims
I believe they will, you will need to be creative on the caps though
Clyde65
Rebuild of Clyde
support our troops!
Thread Tools
Display Modes
