Old 12-03-2012, 12:09 AM   #1
travz500
travz500's Avatar
wanna see your V-8 motor mounts
I got a 65 3/4 ton 4x4 that has tubular bar from frame rail to frame rail and the mounts are mounted to it I dont really like it but its there I was just wondering what all you other guys have switched to I am planning on a 572 eventually that is pumping none other than 650 hp just not sure i like the mount I got but want to see what others have thanks mine has a small block in it now
travz500 is offline   Reply With Quote
Old 12-03-2012, 12:17 AM   #2
padresag
Re: wanna see your V-8 motor mounts
show us a picture of it, sounds like something that someone installed. where are the mounts situated and what trans is in there. is this also an original 4 x 4 or an after thought one?
ron
padresag is offline   Reply With Quote
Old 12-03-2012, 12:35 AM   #3
j.kirn
i would love to see this as well
j.kirn is offline   Reply With Quote
Old 12-03-2012, 12:48 AM   #4
travz500
travz500's Avatar
yes its originally 4x4 the mount however is not it has the 4 speed tranny will get a pic here in a bit and instead of bolting into the frame they welded it but this is the one thing that was welded that is actually welded good the rest of the crap I have spent hours removing and cleaning up was not good welding infact more like chicken sh!t welds
Old 12-03-2012, 01:11 AM   #5
travz500
travz500's Avatar
Old 12-03-2012, 01:21 AM   #6
Captainfab
60-66 Nut
I can get you a pic of the stock '63-'66 4x4 motor mount brackets tomorrow. If you are installing a big block, especially a tall deck, you will not be able to install the engine with the motor mounts in the original location. For what you are planning, I would convert to either a '67-'72 4x4 engine crossmember, or better yet a '73-'87 engine crossmember. The '73-'87 motor mount brackets will need to be modified to fit the early frame. However the '73 ans up motor moujhnts are far superior IMO. With either one, you will have to mock up your engine, trans and transfer case combo, so that you can position your motor mounts where they need to be for adequate firewall clearance.
Here are a few pics of a '67-'72 motor mount crossmember we installed in my son's '63 4x4
Old 12-03-2012, 01:22 AM   #7
travz500
travz500's Avatar
Heres a couple more pics not sure how to rotate the pics
Old 12-03-2012, 01:29 AM   #8
travz500
travz500's Avatar
I actually was thinking of using my 87 blazer crossmember and just trimming it down to fit the shorter frame of the 65 gonna use the cross member anyhow when we change motor to my 383 till I can afford to switch to the 572 I really really want to build (wife would kill me if I did it now) so I have to build my small block instead but gonna shoot for 500 with it got one now that is close sitting in the shop I already took all the suspension 8" lift springs and all shackles and put on the 65 frame just finished cutting new front shackle holes and drilling everything
Old 12-03-2012, 01:42 AM   #9
Captainfab
60-66 Nut
I would modify and use the '87 blazer crossmember.
Old 12-03-2012, 01:54 AM   #10
wyomech
wyomech's Avatar
If you check in the 4x4 build section I have pics of a 87 suburban crossmember and mounts that I used in my 63 4x4 conversion you do have to cut them down as the frame is shorter
wyomech is offline   Reply With Quote
Old 12-03-2012, 02:30 AM   #11
argonaut
argonaut's Avatar
trav,
the big block is going to have some issues at the firewall in the stock location. I know, I've tried, and mine is just a little 402 with stock low valve covers. I had to shift the whole powertrain 1-1/2" forward to make it sit comfortably.
I had both 67-72 and 73+ crossmembers but went with the 67-72 in my 66.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 12-03-2012, 02:48 AM   #12
travz500
travz500's Avatar
Originally Posted by argonaut View Post
trav,
I am planning on moving it 2" if I can I dont run a fan blade I am gonna use electric fans
Old 12-03-2012, 03:17 AM   #13
argonaut
argonaut's Avatar
What transmission are you going to use? You probably already know that once you move the engine forward 2" that the old bellhousing mount crossmember will no longer work, and neither will your stock mechanical clutch linkage. Obviously if you are switching to an automatic with a new rear crossmember then it isn't a big deal at all!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 12-03-2012, 04:19 AM   #14
padresag
is this a converted 4 x 4 or is it just the newer suspension installed. that is not the orig trans or tran case. more than likely a sm364 with coupled t/c
ron
Old 12-03-2012, 06:10 AM   #15
bk2life
why not build or find a bbc and install that? that way all the problems you are going to run into are done and out of the wya for that 5Z2? your puttin a sbc in its place and nothing will work in the long run for the bbc, such as engine/trans placement....
bk2life is offline   Reply With Quote
Old 12-03-2012, 06:59 AM   #16
hd74
i have a 454 in the stck location and a hei. 1962 gmc are the chevys differant? mine had a v6.
hd74 is offline   Reply With Quote
Old 12-03-2012, 08:45 AM   #17
62 short step
62 short step's Avatar
This is what I did on my 61 4x4.
I used a 67-72 x-member.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 12-03-2012, 10:16 AM   #18
travz500
travz500's Avatar
Its a 465 tranny and I put the 87 suspension under it moved it all to line up properly and yes I know it will have to move gonna use a 350 and 208 unless I get my 400 and put together gonna use the crossmember with my tranny and t -case and drill new holes
Old 12-03-2012, 10:24 AM   #19
travz500
travz500's Avatar
We got a lot of work ahead of us brake lines need moved and reran frame is gonna get shortened to a shortbed putting newer style gearbox on off the 87 also spent a hour and a half getting all the frame rails cleaned of all the crap that was gobbered on from the previous powersteering
Old 12-03-2012, 06:35 PM   #20
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I just used a 73-87 x -member in my suburban frame,just had to chop down the mount towers a bit.
build pics in my signature: \/
Thread Tools
Display Modes
