12-03-2012, 10:55 PM | #1 |
Real Projects never die
c/20 and c/30 single and dual wheel differences
At least in the front brake area. Could I take the disc setup off of a 71 c20 and swap it onto a 69 c30 dually and simply put the dual rear wheel brake rotor/hub assembly onto the 71 spindle to keep dual wheel width? Are the calipers and spindles the same between the 2?
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
12-03-2012, 10:57 PM | #2 |
Re: c/20 and c/30 single and dual wheel differences
http://67-72chevytrucks.com/vboard/s...ke+dually+swap
Looks like from this thread, txfirefighter said they are in fact the same. has anyone ever done the swap and confirmed this?
12-03-2012, 11:22 PM | #3 |
Havent done it, but yes you can, if you're referring to putting a 71+ extra deep DRW rotor/hub onto a 71+ 3/4 T disc brake spindle. I dont believe a drum spindle will accomodate a rotor/hub - no caliper mounts.
12-04-2012, 12:07 AM | #4 |
So you want to add front DRW disc brakes to a 69 C30? In the long run swapping in a '73 up later setup (control arms too???)will yield thicker rotors +.25" and parts you can actually buy at a parts store. There is a thread on this from like a month ago that should come up in a search. Try "ss tim" brakes . Think about a hydroboost too.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-04-2012, 12:42 AM | #5 |
I can get the front end off a 71/72 for a relatively good price. I thought about the 73-87 swap since those are mainly the years I work with but the 71/72 is already sitting there for me at a good price. Hydroboost would def be on the to do list as well as other comfort things before long hauls.
Ill be using everything I need from the 71/72. I know that the drum spindles wont work. And I want to make sure I can fit the jb8 calipers up front. I dont know if id ever be able to notice the difference between them and the later bigger discs. Thanks for the feedback so far. Glad to know I can slip drw rotors over the single rear 71+'s.
12-04-2012, 05:37 PM | #6 |
will the 77 rotors work on the 71 spindles?
12-04-2012, 06:43 PM | #7 |
The 3/4 ton spindle will not accept the 1 ton caliper
12-04-2012, 06:55 PM | #8 |
You sure about that ?
http://67-72chevytrucks.com/vboard/s...25&postcount=5 Its my understanding the 1 ton calipers are the same 7" pin spacing, except larger bore and wider throat - for the 1.50" thick rotor vs. 3/4 ton 1.25" thick rotor. As long as you keep the caliper & rotor paired together, either will bolt onto the C20/C30 spindle. Folks only use the 77 year as a convenient reference point when sourcing parts from yards or parts stores, since it was the last year of SAE threads before the caliper banjo fitting (among other fasteners), went to metric. |
Thread Tools | |
Display Modes | |
