Old 12-04-2012, 04:11 PM   #1
Hduramax
Hduramax's Avatar
crossmember question?
I am sure this is been asked on here a bunch, but I am doing a 5 front,7 rear drop on my 69 C -10 and was wondering why the trailing arm crossmember needs to be moved forward a inch?
Thanks for any help
2008 HD
2010 Camaro 2ss (The Wife's Ride)
2005 Suzuki GSX-R 1300 "Busa"
1969 C-10 (under Construction)
2013 Sonic LT
"LIVE LIFE,TASTE DEATH"
Hduramax is offline   Reply With Quote
Old 12-04-2012, 08:46 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: crossmember question?
It doesn't.
Keith
Convert to disc brakes.
Old 12-04-2012, 11:41 PM   #3
oldman3
oldman3's Avatar
I'm no expert, but I would also say no. Did a 5" rear drop on a 67 and didn't move anything...Jim
oldman3 is offline   Reply With Quote
Old 12-05-2012, 12:13 AM   #4
gearys 5600
gearys 5600's Avatar
It doesn't.
x-2
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 12-05-2012, 12:45 AM   #5
BMERDOC
BMERDOC's Avatar
I agree with the other guys but I wanna complicate the situation. I saw this thread earlier and have been thinking about arcs and suspension travel all day. If the truck is dropped with springs the wheel will move farther forward in the wheel opening as it is lowered. The last thing you'd wanna do is make it even worse by moving the crossmember further forward. I think you'd wanna move it back if anything. Some of the aftermarket crossmembers offer adjustability if you wanna go to those lengths so it does hold some merit. The first thing I'd do is knock out the rivets of the trailing arm brackets on the crossmember and flip them upside down to put the forward end of the trailing arm higher in the truck to correct the geometry. If you wanna be anal, mark the centerline of the rear wheel opening and adjust the rear suspension so that the rear wheels are centered. In short, you dont have to touch a thing (did I mention c notches?) to drop it that low in the rear but you can if you wanna take it a step further.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-05-2012, 03:49 AM   #6
thekid54
Call me crazy, but I think the rear wheel will move backwards when the rear is lowered with springs. As the rear end moves up through the arc it will move farther away from the front wheel. Now, when the axle is above the frame rail (like with a step notch) then the wheel base would shorten slightly.
thekid54 is offline   Reply With Quote
Old 12-05-2012, 07:35 AM   #7
Hduramax
Hduramax's Avatar
Thanks for the responses, i am still digging into this myself, but all thoughts help
Thanks guys
2008 HD
2013 Sonic LT
Old 12-05-2012, 09:07 AM   #8
andrewmp6
I have never seen anyone move it just a lot that replaced it with some kinda aftermarket one tho.
andrewmp6 is offline   Reply With Quote
Thread Tools
Display Modes
