Old 12-07-2012, 10:23 AM   #1
slaminum69
slaminum69's Avatar
Help! Intake and exhuast gaskets on inline 250????
Hey everyone, I have a question in regards to the intake and exhaust manifold gaskets, trying to figure out the mating or installation of the gaskets. I Know on the gasket that mounts to the header the flat side goes towards the header with the metal facing the intake and exhaust ports am I correct on this???? the one that is baffleing me is the one for in between the the intake and exhuast below the carb, I have two gaskets one that is solid and one that is just the outline of the manifold, so which one goes in there and which way does the metal side face, intake or exhaust side???? Keep in mind this is for a stock inline 250, I have searched but cant find any info on this so I appreciate everyones help on this. Thanks...............
Dennis N.
USN Ret.
Patriotism is your conviction that this country is superior to all other countries because you were born in it.
slaminum69 is offline   Reply With Quote
Old 12-07-2012, 11:28 AM   #2
1963c-10
1963c-10's Avatar
Re: Help! Intake and exhuast gaskets on inline 250????
Use the one w/the cutout and I put the metal side towards the exhaust manifold.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-07-2012, 02:52 PM   #3
sigshooter
sigshooter's Avatar
ditto
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 12-07-2012, 05:46 PM   #4
slaminum69
slaminum69's Avatar
Thanks, I do appreciate it, thought I had maybe doing something wrong but had it right all along, guess I am gong to have to put some copper gasket goop on it, to isolate the leaks. Thanks again
Dennis N.
USN Ret.
Old 12-07-2012, 05:48 PM   #5
1963c-10
1963c-10's Avatar
Yeah, it'll help. Also...if you leave the intake/exhaust bolts a little loose when you mount the two back together, it'll make alignment a little easier. Once you have the manifolds bolted to the head, then tighten up the 3 that hold the two manifolds together.
Old 12-07-2012, 09:26 PM   #6
gimmy 64
also put the gaskets on torque them down start engine warm it up then let cool and retorque
gimmy 64 is offline   Reply With Quote
Old 12-08-2012, 11:47 AM   #7
theastronaut
theastronaut's Avatar
Check the flanges to see if they're flat. They may be warped which would make them not seal evenly.
theastronaut is online now   Reply With Quote
Old 12-08-2012, 12:22 PM   #8
Aflac
good plan. I learned the hard way long ago to not tighten anything down until you have all bolts in something. Makes you really good at taking things apart to get it right!
Aflac is offline   Reply With Quote
Thread Tools
Display Modes
