Old 06-06-2003, 12:17 AM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
How to hotwire the glow-plugs
I have a 86 with a 6.2 diesel (ya, I know) and it will start fine when mostly cool if the glowplugs come on. If I run it and get it warm enough for the glowplugs to decide they don't want to come on, the pot-licker won't start short of a 30 second grind contest on the starter motor. Is there a way to put a button on the glowplugs? OK it will have to be a high capacity button, but that's OK.
Thanks in advance
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 06-06-2003, 02:49 AM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Scrap the high-amp button plan & use a FURRD (can't bear to use the correct spelling) starter solenoid. That way, your pushbutton is only carrying low amps to trigger the sol. I do this on customer's trucks quite often.
jeffspower is offline   Reply With Quote
Old 06-06-2003, 05:39 AM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Here's a good link to show you how to do that. http://www.novaresource.org/starter.htm
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 06-07-2003, 11:24 AM   #4
RockHQ
ROCKET POWER!
RockHQ's Avatar
Scrub said the problem with the engine is related to the glow plugs ie inability to start, but not to the starter ie inability to crank. There are a few different glow plug controllers and wiring used during the production run (1982-1993 for the 6.2). The general rule is the newer the better. If you have a 1985-1993 6.2 (i'm assuming a 1986 model) then the wiring for a glow plug override button is simple.
The glow plugs are energized by an electronical controller below 125 degrees Fahrenheit. The controller has a temperature inhibit switch wired to it which simply opens at around 125F. When the switch is open (non-conductive) an operational amplifier inside the controller inverts to ground, preventing glow plug operation.
To wire the manual switch, you simple need to put a jumper wire to override the temperature switch, allowing the controller to energize the glow plugs. You don't actually power up the glow plugs with the switch, so it needn't be capable of high current.
When you need to manually operate the glow plugs, turn the ignition off, then flip the switch you installed, and do a normal startup (pre-glow, crank, after-glow sequence).
The temperature switch is located at the rear of the right cylinder head next to the vacuum pump. It should have 2 wires going to it, these you will need to connect together (via the switch you'll install).
If you have more questions or you don't have an electronic controller (older style glow plug system) just ask me and i'll throw in more information.
-Axle
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 06-07-2003, 04:21 PM   #5
arveetek
Ultimate Diesel Dude
arveetek's Avatar
Yep, follow Axle's advice regarding the temp. inhibit switch. GM installed this switch to prevent the glow plugs from cycling when the engine was warm. However, some diesels still need a glow period during that "lukewarm" stage when the engine isn't hot, nor is it cold. GM later did away with the switch.
You could also simply totally eliminate the inhibit switch by splicing the wires together located at the switch. This will allow the plugs to cycle every time the key is turned on.
And by the way, chin up! Owning a 6.2L diesel is a wonderful thing!
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's
Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's
arveetek is offline   Reply With Quote
Old 06-08-2003, 02:34 PM   #6
Scrub
Scrub's Avatar
WOW!
Thanks troops, That really makes it easy to accomplish the task.
The folks on this board are GREAT!
Thanks again
Scrub
Old 06-20-2003, 11:59 PM   #7
Scrub
Scrub's Avatar
OK,
I finaly got some time to do this, but I think maybe I have a different system. I don't see a vacuum pump.
I think I need to short the 2 wires with red arrows, which go to what looks like a heat sensor to me. The green arrow is one of the same wires. Sorry, it's not the best picture
TW
Scrub
Old 06-21-2003, 01:28 AM   #8
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
NO! NO! not those! The green wires pictured go to the fast idle solenoid & cold start solenoid inside the injector pump. The red one is the fuel shutoff. You want the wires at the rear of the engine. The glow plug controller is at the rear of the driver's head on the top. The vac. pump is where the dist. is on a gas burner. The temp. inhibit switch is at the rear of the passenger side head to the rear of the exhaust manifold (usually).
Old 06-24-2003, 04:06 PM   #9
Scrub
Scrub's Avatar
I feel like a Kompleat Edeyutt.
OK, I think I got it.
I guess I can either short the two wires, or put a switch between them,
Correct?
Thanks again.
Scrub
Old 06-29-2003, 01:20 AM   #10
Scrub
Scrub's Avatar
Hmm,
I put a switch in between the two wires in the last pic, and it didn't seem to do anything. I even pulled the connector and direct shorted the two wire and nothing happened. When I say nothing happened, I mean I drove to town and back and turned off the truck. I then did a restart and expected the glow plugs to activate. Narp.. same as before.
Any ideas?
Thank in advance
Scrub
Old 07-05-2003, 02:20 AM   #11
Scrub
Scrub's Avatar
TTT
Scrub
Old 07-05-2003, 11:12 AM   #12
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
This is probably not what you were looking for, but I say scour the junkyard for a duramax and throw that puppy in your truck.. oh the allison trans would be a nice upgrade too
good luck
mike
mike reeh is offline   Reply With Quote
Old 07-12-2003, 05:01 PM   #13
RockHQ
ROCKET POWER!
RockHQ's Avatar
Have you made any progress with the truck yet?
Sometimes the controller becomes heat sensitive as it ages and might do just what's happening in your case. I'd get a new unit and see if it cures the problem. BTW, i could not find a decent picture of the controller but here's a drawing:
Glow controller
Thread Tools
Display Modes
