Old 12-14-2012, 09:37 PM   #1
travz500
travz500's Avatar
Pulling cab tomorrow how did you lift yours off want suggestions please
like the title says gonna take my cab off the frame tomorrow afternoon its already moved back and sitting over the rear axle 4 of us moved it back but i am gonna pull it off the frame my frame has a 8" spring suspension lift so the bottom of the cab is a little higher than waist high was thinking using a strap thru the cab with the doors open but problem is the inside of my cab is all redone by PO and i dont want to mess anything up at all I have a a big 4240 john deere tractor with a loader and was just gonna run a couple of straps thru and lift off and sit in the barn till frame is done any other suggestions? how did you do yours? Just dont want to mess up the cab roof or anything I am open to suggestions
travz500 is offline   Reply With Quote
Old 12-14-2012, 10:36 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: Pulling cab tomorrow how did you lift yours off want suggestions please
Looking at how high it is, I would build it up with pallets or wood on either side, jack it a little higher and then roll the frame out from under it.Either by airing out the tires or removing them and putting the drums on carts. Then you can slowly remove the blocking a little at a time. If you lift it thorough the cab with a tractor make sure you use a spreader bar so the straps don't roll over the roof. This cab got cut up so I wasn't worried about it but it rolled the drip rails up.
LT1 Burb is offline   Reply With Quote
Old 12-14-2012, 10:41 PM   #3
harpo1313
harpo1313's Avatar
ive nailed [2] 2x8s togeather ,wrapped them in carpet, large eye bolts on each side and lift at the door openings.doors off or open.just remember to have a helper up front as the cab is front heavy,your seat weight will offset it somewhat,and keep your 2x8s as forward as possable. i used a forklift.
harpo1313 is offline   Reply With Quote
Old 12-14-2012, 10:58 PM   #4
travz500
travz500's Avatar
well the problem with just building it up is I need to move the cab into my other barn to get out of the way the frame is gonna go get shortened to shortbed length and possibly have blasted and painted not sure on that part yet So I need it out of my way for a good while month or so plus I got to split one of our feed tractors to fix clutch so gonna need my shop back when you did the 2x8 did you run them clear thru the cab? I took the cab off of a 87 chevy pickup the other day but didnt care the outcome of it but we just ran 2 3" straps thru the cab and then closed the doors lifted it up with skid loader and moved it didnt hurt a thing I just dont want to bend up my cab is my biggest deal never took one off I ever cared this much about non were in good shape as this plus if I use my tractor and leave the bale spear on it has 2 spears about 2' apart so it will spread some of the weight out and it wont just be lifting in the center
Old 12-14-2012, 11:12 PM   #5
LT1 Burb
LT1 Burb's Avatar
I also have an extra set of top door hinges I drilled a hole through and put a shackle on them. I run a strap through it and the door striker and it lifts real nice with one on each side, if your bale spear is long enough to catch the opposite side then I would do that.
Old 12-14-2012, 11:14 PM   #6
harpo1313
harpo1313's Avatar
Yes 2x8s all the way through the cab,eyebolts about 5 inches out.if your gonna use straps dont close the doors .it will bow out you doortops and you wont get a good weatherseal.
Old 12-14-2012, 11:41 PM   #7
travz500
travz500's Avatar
you got a picture of that setup LT1?
Old 12-15-2012, 06:53 AM   #8
mark 66
I used my engine lift with the boom all the way out.found a nice strong 4by 6 and laid across the top of the lift and strapped it down. slid the lift inside the cab and lifted it off. depending on how stripped out the cab is will determine where to place the crossing piece of wood.
mark 66 is offline   Reply With Quote
Old 12-15-2012, 10:15 AM   #9
dodgiesdad
dodgiesdad's Avatar
When I lifted mine, I first removed the doors. Then I had built a framework out of 2 X 4's and 2 X 6's braced up and down and front to back. (It fit tight in the door opening to prevent sliding.) I had also used a layer of carpet padding where the framework touched the cab. I then attached chains from this to my chain hoist, being careful to make sure the cab was balanced. I lifted it about a foot of the chassis and then rolled the chassis out from under it. I then had a dolly built with large wheels to sit it on. I was able to roll it around the shop as I needed.
dodgiesdad is offline   Reply With Quote
Old 12-15-2012, 10:56 AM   #10
LT1 Burb
LT1 Burb's Avatar
I dont have a pic of the actual lift but this is how I do all of mine now, you can see the strap attatched in the pic.
Old 12-15-2012, 11:31 AM   #11
rs74
rs74's Avatar
There is a picture here on this forum somewhere that they stuck a 4x4 through the cab. It looked like it stuck out each side about a foot or so. They had tied straps around each end of the 4x4 and then lifted from over the center of the cab. Probably not a bad idea. From what I seen there was nothing to bend in the process but I don't remember if they had the doors on or not.
rs74 is offline   Reply With Quote
Old 12-15-2012, 11:55 AM   #12
Chevy Fleetside
Chevy Fleetside's Avatar
The guy I rent from at a shop had a fork lift.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-15-2012, 12:07 PM   #13
czny
In a month I'll be swapping cabs on my 65 C10. Both cabs have the front & rear holes for the mounts. I thought 2 pcs of chain bolted through the mount holes long enough for the centers to be tied together in the middle & lifted with a cherry picker from the side.
Is there any reason that these cabs can't be lifted at these points?
Just a suggestion...
czny is offline   Reply With Quote
Old 12-15-2012, 12:48 PM   #14
Chevy Fleetside
It has been done before like that. Just make sure you get the balance right. Also if you have the doors off you can get 3 friends and lift it off.
Old 12-16-2012, 10:46 PM   #15
travz500
travz500's Avatar
Here is how we did it worked well ran 2x4s thru the cab and ran the straps over them
Old 12-17-2012, 07:01 AM   #16
mark 66
found a picture of how I rigged mine.
Old 12-17-2012, 07:25 AM   #17
harpo1313
harpo1313's Avatar
glad it worked out,and thanks for posting results.
Old 12-18-2012, 05:12 AM   #18
pdxhall
pdxhall's Avatar
I used 3 friends.
pdxhall is offline   Reply With Quote
Thread Tools
Display Modes
