Old 12-15-2012, 10:41 PM   #1
mattmann527
mattmann527's Avatar
Bagging 65 c10
New member here. Just got a 65pu back in summer and been doing a few odds and in to it. I have decided that i am going to put air bags on it but dont want the complete frame dragger. I mostly plan on just replacing front springs with bags and rear with bags and bolt in c-notch. Now question is does anyone have a picture of how low this will set me with out altering the front control arms besides bag plates and such. thanks
Bare with me on pictures and such. im still trying to firgure out the web site and im not to computer savy
mattmann527 is offline   Reply With Quote
Old 12-16-2012, 12:35 AM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Bagging 65 c10
Here is my 65 stepper. Swapped springs for bags up front, C notch in the rear. nothing touching the ground, but the cross members are real close.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-16-2012, 12:37 AM   #3
61_FL_Apache
Who Me?
Re: Bagging 65 c10
Front cross member.
The rear.
Steve
2001 Blazer 4D 2WD
Old 12-16-2012, 12:38 AM   #4
61_FL_Apache
Who Me?
Re: Bagging 65 c10
Rear bags.
Front bags
Steve
2001 Blazer 4D 2WD
Old 12-16-2012, 01:21 AM   #5
lil_sahara450r
Re: Bagging 65 c10
something about those pics just look unsafe.... are your bags sitting directly in the spring pockets on the front a arms with no cups?? and the angle of the rear bags just look sketchy too..... i'm not trying to be a butt... but just dont want anyone to get hurt. i hope you can prove me wrong.... and what if you need to access the air lines leaving the bags?? those upper plates look welded in!
lil_sahara450r is offline   Reply With Quote
Old 12-16-2012, 09:17 AM   #6
61_FL_Apache
Who Me?
Re: Bagging 65 c10
Are you saying my old rat rod is sketchy? Well, it probably was..
The rear was done by a previous owner. Yes the bags are on an angle a bit, but I never had any issues with them over the two plus years I owned the truck.. I installed the front bags directly in the spring pockets. I welded in the upper bag plates too. I was still able to access the top of the front bags and remove them. I had an air leak on one of them, but was able to reach my hand and a wrench in there to take the bolts loose..
Hey no offense taken, and thanks for your opinion. Thats what this place is for.. I have since moved on from that truck and on to something better.
Steve
2001 Blazer 4D 2WD
Old 12-16-2012, 09:30 PM   #7
groundbound64
Re: Bagging 65 c10
Nice ride Apache !!! I hope my 64 stepside sits that low when we're done with it this spring !
groundbound64 is offline   Reply With Quote
Old 12-16-2012, 10:43 PM   #8
mattmann527
Re: Bagging 65 c10
Thanks for the pictures Apache. That really helped me decide on what route i wanted to take on the front end and make sure that i wouldn't have some weird rake to the truck when i was finished. That stance is exactly what I am looking for.
Old 12-17-2012, 01:02 PM   #9
theastronaut
theastronaut's Avatar
Re: Bagging 65 c10
Here's a few pics of my frame with bolt in C-Notches and Air Lift D2600 bags. You'll need to use tall bump stops to keep the pumpkin from hitting the bed floor. You'll also need to relocate the shock mounts.
Front bag mounts (the crossmember is upside down).
theastronaut is offline   Reply With Quote
Old 12-17-2012, 11:44 PM   #10
lil_sahara450r
Re: Bagging 65 c10
I'm glad you didn't take offense, because I promise none was ment to be applied. Just trying to be safe ya know.
Old 12-18-2012, 01:08 PM   #11
luvbowties
luvbowties's Avatar
Question Re: Bagging 65 c10
Hi, not to hijack this thread but,theastronaut, what brand shock-remount are we seeing in these pictures? Look quite adaptable & ready to fit about any application. Always enjoy nice-looking work; keep it up!
sam
luvbowties is offline   Reply With Quote
Old 12-18-2012, 01:12 PM   #12
shawno72
C/10 junkie
shawno72's Avatar
Re: Bagging 65 c10
Cool
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-18-2012, 01:25 PM   #13
50bomb
50bomb's Avatar
Re: Bagging 65 c10
So companies sell bolt in kits without having to weld anything? I had to sell my welder to fund for my 67 c10 project. I just want to airbag the rear only and put 3" drop coils up front.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 12-18-2012, 01:27 PM   #14
Pro Performance
Pro Performance's Avatar
Re: Bagging 65 c10
Just replacing the springs with bags will give you a low stance, and will want to get drop spindles as well to get the front as low as possible. Usually this is a good time to do a disc brake conversion as well.
We have our Pro1 Air Ride Kit that uses Porterbuilt suspension products, as well as AccuAir valves and VIAIR compressors. It will have a bolt-in c-notch, shock crossmembers, bags, shocks, adjustable (longer) rear trac bar and everything else you need. Just add the drop spindles.
Let us know if we can help you out any.
http://www.azproperformance.com/Pro1...r-Bag-Kit.html
Rear System
Pro Performance is offline   Reply With Quote
Old 12-18-2012, 01:36 PM   #15
shawno72
C/10 junkie
shawno72's Avatar
Re: Bagging 65 c10
That's a cool kit. One question is I have a CPP notch installed already, if I wanted to go with a Porterbuilt notch how far will the holes be off?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 02:54 PM   #16
Pro Performance
Re: Bagging 65 c10
Not exactly sure to be honest, since I don't have one to compare. From the pictures, it looks like 2 might line up, as far as the side bolts are concerned.
Old 12-18-2012, 03:56 PM   #17
groundbound64
Re: Bagging 65 c10
What size rims are you running? Also under that chrome cap is it 5 lug or 6lug.. I ask this because when I buy my disc convert kit it states " will not work with factory wheels"
Old 12-18-2012, 07:18 PM   #18
61_FL_Apache
Who Me?
Re: Bagging 65 c10
These were 6 lug 15" wheels, maybe 7" wide.
Steve
2001 Blazer 4D 2WD
Thread Tools
Display Modes
