Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Closed Thread
Old 12-19-2012, 01:33 AM   #1
K30_dump
Factory rear sway bar setup
Hello all,
Have a factory rear sway bar setup for sale. Includes the bar and spring plates. Will need new bushings and straps (sold as a kit from Energy) as well as end links.
Factory installation requires downward facing u-bolts with 40.5" spring spacing (1-ton). 1/2 and 3/4 ton trucks used 42.5" spring spacing. May be able to make fit with axle flips, 1/2 tons, etc., but that is up to you. Just want to make the info available .
These are extremely rare, hate to sell this one.
Looking for $150 + shipping. Can post pics if needed, working until morning .
Thanks,
Joe
K30_dump is offline
Old 09-29-2013, 06:00 PM   #2
K30_dump
Re: Factory rear sway bar setup
Bump
Joe
K30_dump is offline
Old 09-29-2013, 07:33 PM   #3
crewcabshorty
crewcabshorty's Avatar
will it fit on 1 ton single wheel ?
crewcabshorty is offline
Old 09-29-2013, 07:43 PM   #4
K30_dump
Should be a direct bolt-on for any 30 series truck, as they use the narrow leaf spring spacing (40.5") and U-bolts that face down. So it should fit perfectly as long as you're a stock 1-ton ...
Hope this helps, thanks
Joe
K30_dump is offline
Old 09-30-2013, 09:29 PM   #5
crewcabshorty
could I see some pictures? where in pa are you? thanks
Old 09-30-2013, 10:30 PM   #6
K30_dump
Sure, I'll try to get some pics in the morning. Located in Jersey Shore, near Williamsport .
Thanks,
Joe
K30_dump is offline
Old 10-01-2013, 03:14 PM   #7
K30_dump
Here are a few pics:
Spring plates were cleaned and painted a few years back, but never run (so a quick topcoat to freshen them up). Bar is in great shape, just needs to be cleaned and painted if desired.
Hope this helps,
Joe
K30_dump is offline
Closed Thread
Thread Tools
Display Modes
