Old 12-24-2012, 01:56 AM   #1
edflores
DJM Spindles, Track width question
How much do djm spindles increase track width?
I have a 78 c10, Zd and has uniball arms with some drop built in, so I lay out, but I was going to add drop spindles to help with alignment, and maybe go 26s.
edflores is offline   Reply With Quote
Old 12-24-2012, 09:59 AM   #2
SCOTI
SCOTI's Avatar
Re: DJM Spindles, Track width question
Drop spindles typically add about 3/8"-1/2" to the track width vs a factory disc brake spindle (depending on the tape measure ).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-24-2012, 07:23 PM   #3
edflores
You sure? I have heard like an inch per side on some people
Old 12-24-2012, 11:58 PM   #4
SCOTI
SCOTI's Avatar
Were they talking about drum or disc spindles? Of all the disc vs disc spindles I've swapped, I've never seen a 1" increase. I've used Bell Tech, Western Chassis, DJM, & AIM products....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-25-2012, 02:58 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
It's all irrelevant.
If you can use a drop spindle to get an easy 2", 2.5", or 3" drop.
Most of the people worried about track width are trying to use the wrong wheel (backspace) for this extreme drop.
CPP Modular spindles are the ones to use if you want the narrowest track width,... with only a 2" drop.
I've never seen any documented info (with pics),... that compare track width differences of the following:
1) drum spindles
2) stock disc spindles
3) standard drop spindles
4) CPP Modular Spindles
Drop your truck.
Order your wheels.
Keith
Convert to disc brakes.
Thread Tools
Display Modes
