12-25-2012, 01:48 PM | #1 |
'72 C20 402 power steering pump
Decided to rebuild my original power steering pump, this was a first time for me doing such. The pump works great but leaks fluid out the front seal and one of the rear orings on the housing. Not a bad leak but bad enough to drive you nuts.
Thinking about replacing the pump with a new or professionally rebuilt unit. Anyone have any good vendor suggestions or the one's to stay away from. Thanks in advance.
Jeff Horsman 1972 C20 Highlander "C" 1966 Olds 442 L69 four speed 1971 Skylark (GS clone racecar) 494 stroker 1986 Buick T-Type |
12-25-2012, 11:38 PM | #2 |
Re: '72 C20 402 power steering pump
I normally would not do this but since the leak is not too bad, try some Morey's brand power steering oil additive. I had a truck that was whining and I changed the pump only to mke the problem worse and then changed it again to creat a leak and frustration so I tried some of that brand of conditioner and not only did the whine stop but the leak did as well. I would normally call B/S on that if it had'nt happened to me and I know for a fact that it worked and masde everything all better, it does'nt cost a whole lot so what do you have to lose? Jim
12-26-2012, 10:35 AM | #3 |
I've used the Lucas power steering additive on several vehicles- import and domestic. It will usually shut the whine off, but not always. That being said, a whining pump may run for years without incident, or it can fail rather quickly- no real way to predict that. For leaks, if the Lucas doesn't cure it, then it is time for a new whatever leaks.
Just my experience with something you can dump into the system and it is a cheap fix, if it works. Posted via Mobile Device |
12-26-2012, 12:05 PM | #4 |
I would "rebuild" it again yourself. The seal and the o-ring kit will be much less expensive than a rebuilt pump. If you are set on not doing it yourself, many of the parts houses have services that build your pump. I know CarQuest does and pretty sure NAPA does. That way you get your pump back that at least you know wasn't in a fire or a wreck. Other than that, get one with a good guarantee-maybe Advance or O'Rieleys.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
12-26-2012, 08:11 PM | #5 |
Active Member
I checked advance auto they sell rebuilt Big Block pumps for about $50 or so with core.
12-26-2012, 08:39 PM | #6 |
Tried adding some of the Lucas treatment without success. That would have been easy.
Thought about buying another seal kit, but that was a messy and tedious process doing the rebuild. Figured since I was not successfull my first go round I might have the same results the second time. I see pumps for sell various places new and rebuilt; though someone on the board might have some insight regarding the p/s pumps on the market. Thanks for all the responses so far guys.
12-26-2012, 08:45 PM | #7 |
Napa has the reseal kit for under $20.00 , comes with the seal and the tin can o-rings.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
Thread Tools | |
Display Modes | |
