Old 12-29-2012, 07:14 PM   #1
379redneck
379redneck's Avatar
Np203 hard shifting into 4 high and low
Anybody know why a 203 would be hard shifting into 4 high and 4 low? Going into 2 is no problem. I have tried it with the truck in neutral and not moving and while moving in gear and it doesn't help. I have to literally hit the shifter as hard as I can several times before it goes into 4
87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift
2000 silverado extended cab stepside 5.3l. Stock for now
379redneck is offline   Reply With Quote
Old 12-29-2012, 08:39 PM   #2
76k10
Re: Np203 hard shifting into 4 high and low
Spray the shifter down with WD40 and try again.
76k10 is offline   Reply With Quote
Old 01-01-2013, 01:38 AM   #3
kenbob87
kenbob87's Avatar
the 203 is a full time 4 wheel drive t case. unless it has an aftermarket 2wd kit installed its always in 4wd....
kenbob87 is offline   Reply With Quote
Old 01-01-2013, 02:21 AM   #4
Redcap
That Rube Goldberg shifter setup certainly leaves something to be desired...
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 01-01-2013, 05:32 PM   #5
LONGHAIR
Yeah, the shifter is the problem. The guts are a bunch of bacically flat plates sliding back and forth inside a non-sealed housing. They get gritty and the "lock" lever won't move. Its a fairly simple thing to remove disassemble are re-install. In most cases, it is easier to do from the top. Just pull up the floor covering and the center "hump" panel.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-01-2013, 07:27 PM   #6
379redneck
379redneck's Avatar
Ok thanks. It does have the part time conversion on it. I will try just using wd-40 first to see if that helps.
Old 01-01-2013, 10:09 PM   #7
OrrieG
OrrieG's Avatar
Search for 203 twin stick. You will see why they have problems. I fought mine then modified it to work as a twin stick. Only took a couple of hours.
OrrieG is offline   Reply With Quote
Thread Tools
Display Modes
