Old 12-30-2012, 10:36 PM   #1
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Lower ball joint install
New parts coming for the conversion to a '71 DB front...
1. Will a block of wood and a BFH work on the lower ball joints, or do I need to borrow the installer kit from Advance Auto?
2. LCAs are freshly painted. Is the bore for the ball joint so tight that it should be stripped of paint and lubed?
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 12-30-2012, 11:16 PM   #2
jayoldschool
Moderator
Re: Lower ball joint install
The BFH often works to pop old ones out, but you'll need the tool to install. You can McGuyver it with a big C clamp and a spacer. I'd clean the opening out, but wouldn't lube it.
jayoldschool is offline   Reply With Quote
Old 12-31-2012, 08:58 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Definitely press the new ones in place. They fit tight enough that if you tried to pound them in place you'd likely mushroom and damage your stuff. It takes a good amount of steady push to get them in and seated fully. The rental tool from the parts store works well if you don't have a shop press. If you do have a big shop press, they work real nicely to press them in.
I always clean the ball joint bores in the arms to clean bare metal prior to installing new ball joints. They fit that tight.
Old 12-31-2012, 10:01 AM   #4
hounddogs!
hounddogs!'s Avatar
I'll do some paint removal and take the LCAs to the shop at work. Thanks for the input guys.
DD '09 Pilot
Thread Tools
Display Modes
