01-01-2013, 08:18 PM | #1 |
Should I swap to a HEI system?
I have this now and the truck just up and died, as mentioned in my other post.
I'm thinking my ignition module went out and I don't think Accel makes my distributor anymore and the module is not as readily available as I would like. Don't the HEI systems replace the coil and innards of the distributor and its a whole lot more reliable?
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! |
01-01-2013, 08:32 PM | #2 |
Active Member
Re: Should I swap to a HEI system?
If parts are not readily available, I would change it. HEI parts are very common.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
01-01-2013, 08:34 PM | #3 |
I went from points to hei and couldnt be happier
01-01-2013, 08:39 PM | #4 |
Moderator
Yes
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-01-2013, 08:48 PM | #5 |
Male or female on your cap? You may need to change your wires or change your ends to fit the hei cap
01-01-2013, 09:19 PM | #6 |
20' Daredevil (Ret)
Do it, you won't regret it. I swapped several years ago to a used GM HEI. It's a completely different distributor and as mentioned, needs different plug wires. You also need to regap your plugs to .045 (instead of .035). It's one of the best things I ever did to my truck -- it's 4WD and the distributor is hard to reach, so changing & setting points was a PITA. Remember to run a 12V lead to the HEI. Pretty sure there's at least one FAQ that tells everything you need to know.
01-01-2013, 09:38 PM | #7 |
DOOOOOOOO IIIIIIIIIIIIIIITTTTTTTTTTTTTTT.My brother use to tell me why don't you upgrade that thang,I finally did and man did it wake up that ole six...
1964 BBC 402 4x4 |
01-01-2013, 11:31 PM | #8 |
Swapped an HEI into mine and it's much better and more reliable.
71 K20 64 GMC mud truck |
01-01-2013, 11:42 PM | #9 |
When I had my six, it made a BIG difference!
=MATTHEW 69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
01-01-2013, 11:51 PM | #10 |
I threw one in mine and went from 10 mpg to 11.5. Pretty significant for just one part. Remember you'll have to get different plug wires.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
01-02-2013, 12:07 AM | #11 |
What LeddZepp said.
01-02-2013, 12:51 AM | #12 |
70+ ( Old Skool Club )
I'm not putting in a plug here for Jegs ( it was the first thing on the Google search ) because you can get these distributors from a lot of vendors and for the price they are a great deal. I've had one of these in my truck since 2007 and I remember when I installed it the truck instantly ran better.
http://www.jegs.com/i/MSD/121/8362/10002/-1
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-02-2013, 01:03 AM | #13 |
01-02-2013, 01:17 AM | #14 |
As I mentioned in your other post, it's the best low-buck upgrade you can make to your truck. You won't regret it.
01-02-2013, 02:05 AM | #15 |
Im also considering doing it myself, i have a few hei caps and i think i also have the distributor in storage if not i have an 85 gmc with a rod knocking that can donate the whole setup including new wires so i think i might go ahead and do it is it just remove it Drop new one in and run a new wire thats 12v ?
Posted via Mobile Device |
01-02-2013, 02:18 AM | #16 |
20' Daredevil (Ret)
That's what I did.... But first I verified timing, then set timing the same after dropping in the HEI. And gap the plugs to .045.
01-02-2013, 02:41 AM | #17 | |
You need a full 12v at the BAT connector and it should be off the IGN so it's only one when you want the truck to run. The stock coil wire has a resistor in in it, so you'll need a new one. It's also a good time to replace plugs and wires. |
01-02-2013, 06:59 AM | #18 |
optomistic ah-so
I thought the Accel distributor conversions used an optical sensor instead of magnetic or Hall effect like HEI, Mopar, Pertronix, etc...the cap on that distributor seems to back that up as it resembles the setup Mallory Unilites run with. If this is true then the little black box that sits where you'd expect the points to be, will have a little window on it that can easily get dirty and prevent the spark from being triggered. Look for the window, and if it's there clean it WITHOUT leaving streaks! and bolt it back in to try it again.
If I sound a little unsure it's because your Accel distributor has the kind of vanes on the center trigger (where the distributor lobes would be) that look more appropriate for Hall effect triggers. If there is one weakness about stock HEIs it's that the ignition modules fail a lot from heat and vibration too. As parts stores have gotten cheaper (NOT less expensive!) the replacement modules fail faster. Make sure your module is securely mounted, using something like heat sink paste as a sealer underneath (not just dielectric silicone or anything normal). Carry a spare module around with you. Some people even wire up the HEI to work from an external Mopar ignition module, which is a bit more vibration resistant.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
01-02-2013, 08:16 AM | #19 |
Thanks for all the responses!
I will be swapping over! I will need some input on how to install it, as me and distributors DO NOT get along. I will start a new thread on help installing HEI. Thanks again!
01-02-2013, 08:21 AM | #20 |
C/10 junkie
You can get a brand new billet hei off eBay for about $45 shipped to your door and they work great. I have one and never worry about it.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
01-02-2013, 01:53 PM | #21 |
optomistic ah-so
Look in the part board for links to the one I am selling on eBay. If the listing expires before you get it I will relist it. I'm going to the parts board now to add the link, so check for the new thread.
I'd normally be happy to sell it direct but I think I'd be breaking a few forum rules if I did :-)
01-02-2013, 05:52 PM | #22 |
Registered Cruiser
Not all HEI's are created equal. In fact, far from it. As with most things, "you get what you pay for." Stock GM HEI ignitions aren't much good above 4,500 rpm. Do some research before you spend good money on a bad ignition.
I've got one of these...http://www.performancedistributors.com/
I intend to live forever. So far, so good. |
Thread Tools | |
Display Modes | |
