01-03-2013, 12:09 AM | #1 |
speedometer & gas gauge problem
both of there needles wobble when i drive, even when im stopped. How can i resolve this?? any help? thanks!
01-03-2013, 11:52 AM | #2 |
Re: speedometer & gas gauge problem
This is an odd problem because the speedo is mechanical and the gas gauge is electrical. The only thing I can think of is you speedo cable might be bad and shakeing the whole cluster housing. If you have a later model(88-91?) with electric speedo maybe its a ground issue.
John 82 Chevy Silverado 350ci/TH350 |
01-03-2013, 01:20 PM | #3 |
If mechanical it could be the gauge or the cable may need to be lubed.....
I had the same problem with the gas gauge...I replaced my sending unit but since my bed is off the truck have yet to be able to test it.....The old one sure was rusted in well though
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
01-03-2013, 04:06 PM | #4 |
A gas gauge needle does move alot because of the float in the tank that moves. (even when stopped the gas can slosh around). Ground not working or only working sometimes? That would probably move the needle on a flat surface since it relies on resistance.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
01-03-2013, 04:35 PM | #5 |
Ok yea ive heard lubbing up the speedometer cable cud help. & where is the ground for the gas gauge
Posted via Mobile Device |
01-03-2013, 04:45 PM | #6 |
It's within the printed circut board on back of cluster. What year is your truck?
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
01-03-2013, 04:55 PM | #7 |
Oh ok. A 78'
01-03-2013, 06:05 PM | #8 |
78K & 79C Jimmys
make sure the cable is locked in for the speedo
make sure the gas gauge power gets it's own ground,they all use one,worked for me
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-03-2013, 09:11 PM | #9 |
Gaa damn ,wires evrywhere ahaha. Alrite I'll look back there. I just hav to know how to get my stereo out because its not the a-track,its a cd
01-03-2013, 11:43 PM | #10 |
is it just me or is that ground nice and crispy?
01-04-2013, 12:01 AM | #11 |
78K & 79C Jimmys
Na it's just blurry
Thread Tools | |
Display Modes | |
