Old 01-03-2013, 01:21 AM   #1
c10 custom
drop spindles and springs
hi guys would it be possible to have 3 inch drop spindles and 3 inch drop coils on the front end of my 1968 chev truck and not have clearance problems any pictures people have of this setup would be great thank you very much
c10 custom is offline   Reply With Quote
Old 01-03-2013, 01:33 AM   #2
Square_78
Square_78's Avatar
Re: drop spindles and springs
Hello
Well... what size tires and rims are you running? If you have a big tire you might be hitting the inner fenders or fender lip. You'll be getting real close to the ground with your control arms at that height if you have a small tire. Also If you are running a 15x8 rim with a 3" drop spindle you may run into issues with the lower control arms rubbing. If you run about a 27" tire (215/70R15) you should be ok, but that will be a pretty big static drop in front. Mine is down about 5.5" in this pic with 215/70 tires and no rubbing issues. This will be about my ride height after I finish my air ride install.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 01-03-2013, 11:08 AM   #3
c10 custom
how did you get 5.5 drop in the front i have 3 drop spindle and 2 inch drop springs how do you get the other half inch to get 5.5
Old 01-03-2013, 11:30 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
2.5 spindle and 3" spring.
Your a-arms will be REALLY close to the ground.
Keith
Convert to disc brakes.
Old 01-04-2013, 08:36 AM   #5
Square_78
Square_78's Avatar
I cut 3 coils out
It was just temporary to see how it looked. I wouldnt recommend more than 2 coils if you actually plan to drive it. Im not driving it like this. Its getting full air suspension installed in the springtime.
#teamlongbed
Thread Tools
Display Modes
