Old 01-03-2013, 02:03 AM   #1
DBear
DBear's Avatar
Dana 60 on 1976 gmc 3/4?
At the junkyard today and came across a '76 gmc 3/4 ton 4x4, and not sure if it had a dana 44 or 60. The hubs were not locking hubs....they had a cap bolted to the axle ends, they looked like axle hub ends like on a large rear axle or maybe an all the time 4x4. Anybody know what this could be and if gm would of put a dana 60 in a '76 gmc 3/4 ton? Thanks
DBear is offline   Reply With Quote
Old 01-03-2013, 03:05 AM   #2
wilkin250r
wilkin250r's Avatar
Re: Dana 60 on 1976 gmc 3/4?
Most likely it was a Dana44, with an NP203 transfer case. The transfer case is full-time 4 wheel drive, so the hubs are locked all the time, which is why they just have a cap on them. It has a differential between the front and rear driveshafts, but you can also lock them together.
I've got this same setup in my 79 3/4 ton. Corp 14B full floater in the rear, Dana44 up front, front hubs don't unlock.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 01-03-2013, 04:55 AM   #3
DBear
DBear's Avatar
Ok.....i want to possibly put this front axle into my 71 burb, which has a np205 transfer case. How can i make this work....most inexpensive route? Could i add manual lockout hubs? Or is this gonna be a big fiasco? Thanks for ur info bud
Old 01-03-2013, 09:51 AM   #4
Zane M
You can change the axle over to manual hubs if you wanted to use it with your current tcase set up.
Zane M is offline   Reply With Quote
Old 01-03-2013, 10:56 AM   #5
Yep. The Dana44 is the same with or w/o full-time 4wd (NP203/205). The hubs are the only difference and they are interchangeable. The l/o hubs are the later smaller design,same size as K/10.
Old 01-03-2013, 11:28 AM   #6
DBear
DBear's Avatar
Other than the closed hubs, is there anything else inside the differential that would need changing?
Just dont want to get into a big mess and money pit!
Old 01-03-2013, 11:33 AM   #7
DBear
DBear's Avatar
Also, when we say manual lockout hubs, you meant the warn style lock outs right? Not the entire hub assemblies? Thanks again
Old 01-03-2013, 12:55 PM   #8
CrewCab59
CrewCab59's Avatar
If it have a bolt on flange with a ring of bolts and a dust cap they are drive flanges , which would have the same hub used with the big spicer hubs.The t-case could be a Np203 or Np205 becuase they used both with drive flanges. If it has a cap than it's just the std D44 / corp 10 hub small hub.
Take a look at the pics in the axle
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 01-03-2013, 01:39 PM   #9
CrewCab59
CrewCab59's Avatar
The drive flanges also came on D60 as well , the steering arm will tell what you have 3 bolt D44 and corp 10, 4 bolt D60 .
1971 Chevy C/10
Old 01-03-2013, 02:39 PM   #10
DBear
DBear's Avatar
Hey bud....the axle picture u posted is what that axle hub looks like in the junkyard. Is this a good style and ur saying it will work with my np205 setup???? Thanks again!
Old 01-03-2013, 07:54 PM   #11
b454rat
it will work, but the front end will be spinning all the time. You would need a set of heavy duty lockouts, Ford ones will even fit. Ones listed below would work, nevermind the hilariously absurd price...
http://www.ebay.com/itm/NOS-Dana-Spi...90043f&vxp=mtr
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-03-2013, 08:39 PM   #12
CrewCab59
CrewCab59's Avatar
Yes ,they are stronger than any lockout because all gears nothing to break.Yes they will work with the 205 ,shafts will spin all the time.
If you plan on installing lockouts than you'll need the big hub spicer lockouts or the external flange ,Mile Markers ,Warn . The small hub dana 44 and corp 10 use the same lock out 77-91.
Here are the pics of the warn lockouts
left pre 76 6 bolt flange
right 77 and up.
1971 Chevy C/10
Old 01-03-2013, 10:24 PM   #13
bilfman
bilfman's Avatar
I have been reading the thread, its been all about hubs and that is fine.
Just make sure that your front and rear gear ratios match if you plan the swap. That will be the biggest concern in putting in another axle.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 01-04-2013, 09:19 PM   #14
Mike C
Mike C's Avatar
Yup. What Bilfman said. Went all the way to the bottom to see that he beat me to it. While you grab the front, get the 14 bolt in the back as well. Then you will be set.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-16-2013, 01:59 AM   #15
Dooley
Dooley's Avatar
At the junkyard today and came across a '76 gmc 3/4 ton 4x4, and not sure if it had a dana 44 or 60. The hubs were not locking hubs....they had a cap bolted to the axle ends, they looked like axle hub ends like on a large rear axle or maybe an all the time 4x4. Anybody know what this could be and if gm would of put a dana 60 in a '76 gmc 3/4 ton? ThanksPosted via Mobile Device
GM did not use the Dana 60 front axle until the 1977 model year in 1 ton 4x4's.
If there is a Dana 60 series front in any thing less than a GM 1 ton square body, and before 1977, somebody else installed it.
Dooley is offline   Reply With Quote
Thread Tools
Display Modes
