Old 01-06-2013, 12:58 PM   #1
Hx16457
Hx16457's Avatar
64-66 C10 windshield install help
I need some coaching on the string method. I have 3 or more people to help.
I do know that the "brow" of the cab will not allow me to set it in from the bottom first, so it look like I will have to hold it up at the top first then start pulling the string around holding pressure on the outside pushing in!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 01-06-2013, 01:29 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: 64-66 C10 windshield install help
Im no pro But when I did it I used a 1/4 rope and hot soapy water. I put the rope in the rubber channel all the way around until it stopped and joined in the middle btop of the INSIDE window. With your other two helping, slid the top of the rubber in and have them add preasure with their hand starting at the top and working your way pulling the rope so that the rubber will rap the metal.
Im not saying its the best way. it was my first time. but it worked ok...dont force the rubber with the rope...you can rip it..have a spray bottle of soapy water handy.
Good luck
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 01-06-2013, 04:29 PM   #3
chevyrestoguy
chevyrestoguy's Avatar
The '64-'66 windshields, especially with the Custom Cab windshield chrome trim, are one of the hardest windshields to install. The brow on the top doesn't allow you start at the bottom and work your way up like you would normally on any other windshield. You have no room to work with on the top. I wonder how the guys on the assembly line did it when they were stamping out about a thousand of those trucks a day?
It's a tough install, I feel for you.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 01-06-2013, 04:35 PM   #4
Hx16457
Hx16457's Avatar
Well thx, luckily I don't have the custom trim, thank goodness! Just the seal!
Old 01-06-2013, 05:15 PM   #5
RANDY COX
RANDY COX's Avatar
that's good yo know,I would have tried to start @ bottom....
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-06-2013, 08:32 PM   #6
duallyjams
duallyjams's Avatar
Here is how I did mine ( custom trim ) laid the windshield flat on the channel , took a hook tool and started on the bottom and worked the the seal over the channel once the bottom was started that's when we pulled the rope/string to work the rest of it in it still took a lot of pushing and slapping with a open palm. There is a you tube video of a 67 windshield install that is really good on showing how to use a hook tool and how to get the seal started to use the pull rope.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-07-2013, 01:24 AM   #7
dracko
dracko's Avatar
Yeah I think this is the vid Dually is talking about. Very helpful info.
Might be worth investing in the gasket hook.
dracko is offline   Reply With Quote
Old 01-07-2013, 09:07 AM   #8
duallyjams
duallyjams's Avatar
That is the exact video I was talking about , it is very helpful.
James
IG duallyjams
Old 01-07-2013, 09:39 AM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=512379
66 C20 Service Truck:
Old 01-07-2013, 12:19 PM   #10
Hx16457
Hx16457's Avatar
Originally Posted by LostMy65 View Post
thanks this will help Bunches!
Old 01-07-2013, 05:47 PM   #11
RANDY COX
RANDY COX's Avatar
Nice video,I don't mind taking mine out but when it comes time to replace I will let the pro's do it.....
1964 BBC 402 4x4
Old 11-05-2014, 09:27 AM   #12
wayno
I'm tackling mine now... I think I'm like a quarter inch too far to the right - any thoughts on whether I can add more soap and water and a couple of suction cups from harbor freight and get this thing to center in the opening or should I work the seal back out and try again for the 3rd time - this thing has been a $#@$@
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 11-05-2014, 10:32 AM   #13
cg285
they had women doing it
cg285 is offline   Reply With Quote
Old 11-05-2014, 10:42 AM   #14
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
when they did the windshield in my sub they were using some suction cups like that.
Old 11-05-2014, 01:16 PM   #15
wayno
so send the lady out hmmm... would end up with new glass and a professional doing the job... not a bad approach cause if I keep screwing with this one I might throw it lol
Old 11-05-2014, 01:18 PM   #16
wayno
it's so close it's maddening... I'll give that a shot - hate the thought of yanking this thing back out.
Old 11-07-2014, 11:37 PM   #17
wayno
So picked up a couple of suction cups from harbor freight and an awl... worked the seal back out on the top and sides... used the suction cups and was able to bump in the quarter inch I needed... flipped the suction cups back to the inside and used the awl while pulling on the glass inward (pains of having all daughters) - and was able to finally get the windshield in - thanks for all the help guys.
Thread Tools
Display Modes
