Old 01-06-2013, 09:18 PM   #1
larsguitars
weak disk brakes
Hey all,
I have just installed a four wheel disk brake kit from CPP on my 65 c-10. The brakes have been bleed and the brake pedal is solid. Problem is the brakes are weak and you have to push hard on the pedal. I need some ideas of what look for to solve my weak brake problem. The old drum brakes were much more powerful than the new disks.
THANKS!
Lars
larsguitars is offline   Reply With Quote
Old 01-06-2013, 09:59 PM   #2
harpo1313
harpo1313's Avatar
Re: weak disk brakes
are you running a booster?
harpo1313 is offline   Reply With Quote
Old 01-06-2013, 10:04 PM   #3
jayoldschool
Moderator
You'll need a new (disc specific) master to get good braking with front discs. Of course, power booster will help.
jayoldschool is offline   Reply With Quote
Old 01-07-2013, 12:58 AM   #4
larsguitars
Hi Jay,
I have everything in the kit, dual master cylinder, booster, prop valve, brake lines, disks, calipers, the whole thing in one kit for my model of truck.
Lars
Old 01-07-2013, 01:03 AM   #5
larsguitars
Hi
Yea I got the whole kit, double master cylinder, booster, prop valve, disks, calipers, lines, all designed to work together.
Lars
Old 01-07-2013, 07:24 AM   #6
brokenspoke
brokenspoke's Avatar
Sounds like something is defective......I would contact CPP
brokenspoke is offline   Reply With Quote
Old 01-07-2013, 12:12 PM   #7
luvbowties
luvbowties's Avatar
Here's a second on brokenspoke's advice...
Sam
luvbowties is offline   Reply With Quote
Old 01-07-2013, 12:44 PM   #8
Herman
make sure the valve on the vacuum line is not backwards
Herman is offline   Reply With Quote
Old 01-07-2013, 01:31 PM   #9
cortcomp
cortcomp's Avatar
What herman said, and of course, if you have a rumpy motor with like 10 inches of vacuum, that's an issue too. Also, i've heard of prop valves being kind of "Sticky" while pumping it up, tap on it lightly with a hammer, and bleed it again. If you're using a mighty vac, try the old method of having a friend pump it and hold while you crack bleeders.
If you want to be super diagnostic, get one of the pressure gauges that screw into a bleeder port and tell you the PSI you're getting at each wheel, will help you find out if it's an overall issue or just prop valve/master related.
Lastly, i had a problem like this in my '71 pontiac. Redoing the back brakes, and new pads on the front (EBC) quadrupled my stopping power, it was an amazing difference. Cheapy pads + not bedding in right kind of killed the stopping power. Back brakes helped from mildly leaking wheel cylinders. Likely not the issue on yours since you have new 4 wheel discs, just throwing it out there.
cortcomp is offline   Reply With Quote
Old 01-07-2013, 03:36 PM   #10
larsguitars
Thanks to all for the ideas.
Thread Tools
Display Modes
