Ok, so one of the previous owners of my 66 painted the grill and front bumper with some aluminum color paint.It looked horrible and gave my truck a monochromatic appearance.I have always liked the nostalgic appearance of the bumpers and grill painted white. my rear bumper was white ok rust lol and needed a lot of love.
I removed the grill (3 screw on each side located on the front underside of the inner fender wells) and sanded it with 150 then 320 and painted it with several thin coats of ace hardware's premium enamel gloss white spray paint, allowing 15 minutes of flash time in between coats. The bumpers had a lot of paint on them ,so I grabbed the orbital and some 60 grit and took them to bare metal . I had to do a good bit of sanding paying special attention to the pitted areas. Then I sprayed them with several thin coats of high build primer allowing 10 minutes of flash time in between coats. after a couple hours of drying time I sanded them lightly with 320 grit paper followed up by a final sanding using a scotch brite pad.then wiped them down good with a prep towel I applied several thin coats of the gloss white allowing 15 minutes flash time in between coats. I used a can of white on the grill, and a can on the front bumper, as well as a can on the rear.The one can of high build primer was enough for both bumpers. the bumpers were painted on the truck and you would never know, just take time to mask properly avoiding over spray. I am VERY pleased with the results it took roughly 6 hours and $40 and made a huge difference .Ok,picture time!! before and after ![]() ![]() ![]() ![]() |
Re: I painted my bumpers and grill today
Looks much better...
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
64-66 CHEVY JUNKIE
Look real good..
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
![]() Join Date: Oct 2011
Looks nice!! Have you thought of maybe paintin the grill surround white too instead of black?
1960 Chevy Stepside 2wd 1966 Chevy Fleetside 2wd 1965 Chevy Suburban 2wd 1965 Chevy Fleetside 4X4 1960 Chevy Fleetside BBW 2wd |
Yes,actually, the whole truck will be painted in the not so distant future. The bumpers and grill were an eyesore and I figured I could handle that
Posted via Mobile Device |
Thread Tools | |
Display Modes | |
