Old 01-13-2013, 05:16 PM   #1
tbeede
Question 1958 steering box with tilt wheel
Has any one installed a tilt steering wheel on a 1958 truck? I want to use the original steering box, what problems do I having cutting the existing column and shaft? any help or pictures is needed.
tbeede is offline   Reply With Quote
Old 01-13-2013, 09:33 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1958 steering box with tilt wheel
Normally most guys are going the other way and used whats called a column saver.
http://www.ecklerstrucks.com/chevy-t...1960-1972.html
You can use a column saver but use it on the box instead of the column. Just make sure you cut the column at the larger diameter above the box.
Here is a write up of old column new box so just flip the idea.
http://www.classictrucks.com/tech/09...l/viewall.html
dwcsr is offline   Reply With Quote
Thread Tools
Display Modes
