Old 01-18-2013, 03:49 PM   #1
Jake's 72' blazer
250 inline help. carb question. pics.
I have a 72 blazer with the inline 250. Just got a orig 1 barrel intake and a remanned rochester monojet carb. (It had a offenhauser 4 barrel with a holly 2brl. setup wasnt working.) Im trying to figure out where to hook up my vacuume lines. in the first picture i was thinking. PCV valve line from the valve cover on the left, vacuume advance in the middle, and vacuume brake line on the right. That is the only lines i believe i have. Will this work?
Also there are two small lines comming off the side of the carb and i dont know what they are for. Can i just cap them off?
Thank You.
Jake's 72' blazer is offline   Reply With Quote
Old 01-18-2013, 06:23 PM   #2
RANDY COX
RANDY COX's Avatar
Re: 250 inline help. carb question. pics.
Yea i would just cap'em off.....
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-18-2013, 07:35 PM   #3
RANDY COX
RANDY COX's Avatar
do you have any more pics of your Blazer is it 2x2 or 4x4..
1964 BBC 402 4x4
Old 01-18-2013, 09:13 PM   #4
alex 68swb
Junior Member
alex 68swb's Avatar
i got a 70 2wd with 250 hope pictures help, the one in front of carb goes on air cleaner in mine, the last pic is what it connect to. The two on side go to vaccume in 3rd pic.
alex 68swb is offline   Reply With Quote
Old 01-19-2013, 06:07 PM   #5
Jake's 72' blazer
thanks fior the imput guys. its a 2wd 3spd on the floor. fresh motor fully redone 20 years ago and not run since( except for a few times within the last few years.)
alex, where do those vacuume lines go that split into a tee? is all i need the pcv/valve cover line(dont know the term), vac advance and the vac brakes?
just wanted to make sure i hook em up correctly so i finally turn it over again. pretty excited to see how/ if this totally diferent setup will work!
i got plenty of pics. its on a lift for the winter to finally finish it so i can photo anything. anything in particular u want pics of?
Thread Tools
Display Modes
