Old 01-18-2013, 08:40 PM   #1
MattPSU
MattPSU's Avatar
24v Solenoids
Can I use 24v solenoids for the air suspension in my truck? I have access to a a bunch of 24v ASCO solenoids for free and I'm curious to know if they could work as is or there's a way to make them work.
Thanks,
Matt
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 01-18-2013, 11:44 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 24v Solenoids
It depends on the lower voltage limit. If its 18v minimum to operate then no you can use the. If its 10v most likely but they may be sluggish to open or close or prone to sticking in one position.
dwcsr is offline   Reply With Quote
Old 01-19-2013, 11:22 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 24v Solenoids
I would look closely at the specs. Are you sure they are bubble tight?
Personally, I would never use anything that wasnt intended for my specific application
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-19-2013, 11:31 AM   #4
fattyarbuckle
Re: 24v Solenoids
yes, you can use a 24v ~ on a 12v -
works like a charm...
make sure the ampes are correct going through the contacs though.
fattyarbuckle is offline   Reply With Quote
Thread Tools
Display Modes
