01-21-2013, 01:06 PM | #1 |
Need help on gears for my 87 R10 and new 383
I am about to install a 383 motor into my 87. It has a 700r4 tranny and the current rear is an open 2.73. I will never be racing the truck obviously and gas mileage is my min concern but I read a few posts here where people actually gained mpg going to a 3.42 or 3.73 gear ratio. Given the new motor and additional power should I change the gearing or am I going to get the best mileage out of the 2.73's? Thanks for the input!
Posted via Mobile Device |
01-21-2013, 01:15 PM | #2 |
Re: Need help on gears for my 87 R10 and new 383
3.73 gears will be perfect for that truck, with the overdrive trans.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-21-2013, 01:17 PM | #3 |
Will it actually drop my mpg or help it? I always thought going to a 3.43 or 3.72 would hurt gas mileage. I appreciate all of the help.
01-21-2013, 02:27 PM | #4 |
Should also add I am running 31x10.5 tires and its a 2wd.
01-21-2013, 02:41 PM | #5 |
18 Till I Die
I would go 3:42 since you have the overdrive trans M2C
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
01-21-2013, 04:07 PM | #6 |
Mileage in city may be better but you may lose some highway mileage.
Where does your engine feel strongest? Not fastest or anything but the happy spot where it cruises? 3:42-3:73 is your range. 3:42 aren't bad for that big first gear and racing. 3:73 gears may actually over gear you on the track and make you lose time. So we need to know some engine specs too Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
01-21-2013, 04:12 PM | #7 |
Slots go on anything!
With the 31's, I would look at the 3.73's. If you will be sicking with that tall of a tire, 3.90's may not be out of the question, either.
01-21-2013, 04:29 PM | #8 |
Engine specs:
The crankshaft is by "EAGLE" products, with 5.7" long I-beam rods and SpeedPro pistons with moly rings, giving pump gas friendly (9.2to1) compression ratio. A custom ground hydraulic roller camshaft and lifters, spec's (210/220`@.050" with .500" lift on 112`LSA) with matching valve springs with a power range of 1500-5000 rpm's. Expecting 360hp and 410 ft.lbs. torque. Haven't installed the motor yet. Should receive it in about 2 weeks. The truck will never see the track but will be a daily driver with a mix if city and hwy driving hence the goal to maximize mpg. How will the stock gearing do as opposed to a different ratio? Thanks again for all the info and help! Posted via Mobile Device |
01-21-2013, 05:28 PM | #9 | |
K
01-21-2013, 05:44 PM | #10 |
That's what I was thinking on the 2.73. And I was hesitant to change thinking it would kill gas mileage. How do I figure out which gears I need? I think 3.73 are probably best but picking the right set in summits website is confusing. Don't really know the specs on my rear end.
01-22-2013, 11:44 AM | #11 |
Keith, do i need to look into a posi as well?
01-22-2013, 11:58 AM | #12 |
Motor sounds similar to my setup, i have a turbo 400 with 4:10 gears. A 700 tranny with 373 gears would be about perfect. If you are getting new gears installed you might as well put a posi in at the same time instead of paying twice, as you will probably find you will need the posi.
1985 C10 2004 Avalanche |
01-22-2013, 12:07 PM | #13 |
373 definitely seem to be a popular vote. Now i just have to figure out the details of rear so i can get the right set.
01-22-2013, 12:37 PM | #14 | |
I always like to have a "non-open" diff. K
01-22-2013, 12:49 PM | #15 |
Suggestions on which diff to use and brand of gear? This is like rolling a snowball down hill. LOL. Never as easy as just swapping out the motor. LOL
01-22-2013, 12:53 PM | #16 |
I got a eaton from a 8.5 nova/camaro in mine, works awesome
01-22-2013, 12:55 PM | #17 |
Use this.
http://www.richmondgear.com/101032.html I like to set my drive rpm at 75 at 2200 rpm. That way I can use a 2000 rpm converter, and that leaves me enough of a hole shot not to need the extra gearing. So I would use a 3.90 gear which summit sells for the 8.5. |
01-22-2013, 12:56 PM | #18 |
BAD BOW-Silverado XST
I use engine torque curves to set the ratio. Do you know the projected curve? Put cruise speed RPM at max torque possible.
01-22-2013, 12:56 PM | #19 |
My 383 is very similar to yours and I also have a 2.73 rear gear in a LWB truck, although I swapped in a th350.
The 2.73 rear is horrible. Even as torquey as the motor is, it's a real yawner at low speeds...and I just have a 29" tire. Ill be going to 3.42's and a 28" tire shortly and I expect it to be a night and day difference. With your taller tire, I'd say the guys above who suggested the 3.73's are spot on. Posted via Mobile Device
85 Scottsdale LWB 383 227/235 105 lsa Howards Roller TH350 by Jakes Performance, Sanger TX |
01-22-2013, 12:58 PM | #20 |
What is the over drive ratio?? We are definitely moving into the way over my head category. My main concern is trying to balance mpg and performance and i would be willing to sacrifice a little performance to help on gas mileage.
01-22-2013, 12:59 PM | #21 |
.70 for a 700
01-22-2013, 01:01 PM | #22 |
gchemist, i do not know the projected curve. i can try to find out what has been typical though.
01-22-2013, 01:03 PM | #23 |
Got it. So with a 3.73 ratio,31" tire and a speed of 75mph, i would be turning at 2122rpms with the 700 tranny? I guess that goes back to finding the sweet spot of the motor at cruising speed. 2100 seems pretty goood though. Looks like right now with the 2.73's i am running at 1553 rpm at 75mph. That seems way low. I wonder how that will effect hwy mileage??
01-22-2013, 02:42 PM | #24 |
3.42's totally out of the question? Found a brand new set here locally with a brand new posi unti as well for 350. They are Yukon brand never installed. Seemed like a really good deal.
01-22-2013, 03:11 PM | #25 |
3:42 will give you some better highway mileage but you may be a little low on rpm on the highway with them tall tires. City mileage will be about the Same. Add a posi if you want to get anywere anytime soon. Richmond and Yukon gears are god long lasting gears. Eaton posi is recomended as well
Thread Tools | |
Display Modes | |
