01-24-2013, 10:15 AM | #1 |
Truck Seat Foam
Hey guys, I got member Truckseats hooking me up with a new turqouise cover for my 67, and was needing a little advice on what you guys used for foam? Should I use a kit? Or buy foam and shape it.. Any help I will appreciate.. Thanks Justin
Justin |
01-24-2013, 10:38 AM | #2 | |
Active Member
Re: Truck Seat Foam
If you have the late foam seat, and you can afford it, get the kit but if you can do the foam shaping and have the tools and knowledge, you may be better off. Still going to be expensive though. I wound up getting the rear bench seat from an 86 Chevy crew cab.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
01-24-2013, 11:02 AM | #3 |
Re: Truck Seat Foam
If you are getting a replacement cover from Truckseats, then you should probably get the stock replacement foam (kit). If you were having a custom cover made, then you could mould it. Cutting/shaping foam isn't all that hard, but the stock-style cover won't look right over shaped/cut foam.
That's my opinion anyways.
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
01-24-2013, 02:45 PM | #4 |
Re: Truck Seat Foam
I replaced the foam on the drivers side in my 67. Also discovered the outside springs were broken. Before I started I read Jim's build thread where he rebuilds his seat foam.
http://67-72chevytrucks.com/vboard/s...=456911&page=9 I have a parts 68 that I stole some seat springs out of the passenger side to give my seat a boost. It was a different style seat(thin foam) but I made it work. For my foam I went to a MAC's hardware store with the foam numbers from Jim's thread. For the driver's area it was around $40. I left a little more foam on so I had more cushion. You can definitely tell that it's not the stock foam. I didn't get the shape just right but it's comfortable so I look past the lumpiness. If I remember right replacement foam is very expensive.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
01-24-2013, 09:04 PM | #5 |
Re: Truck Seat Foam
When I did my seat with a cover from Truckseats, I used new foams from American Cushion Industries. I swear I bought them from someone in the vendors forum on this site, but darned if I can find any history of the transaction now that I need it.
Anyway, the foam fit perfectly and made installing the cover easy. It *is* a bit stiff, but probably feels that way because the old foam was so shot my @ss was in the springs... |
01-25-2013, 07:41 AM | #6 | |
72 GMC
Re: Truck Seat Foam
http://67-72chevytrucks.com/vboard/s...d.php?t=433444 |
01-25-2013, 08:16 AM | #7 |
Re: Truck Seat Foam
Thanks for the info guys!
Justin |
01-25-2013, 09:18 AM | #8 |
Re: Truck Seat Foam
Ya, that's the thread, KEL. I bought the foams from PICKMUP. IMO worth the investment.
Thread Tools | |
Display Modes | |
