Old 01-24-2013, 11:58 PM   #1
61memo
12 bolt chevy diff
What would be an ideal gear ratio for my 66 burban 12 bolt diff,original 3 speed manual tranny 235/75/15 tire looking for highway cruising and not to bad city trying to get the best of both worlds ...thanks for any info
61memo is offline   Reply With Quote
Old 01-25-2013, 01:00 AM   #2
HugoV
Re: 12 bolt chevy diff
I would also like to know.
HugoV is offline   Reply With Quote
Old 01-25-2013, 02:22 AM   #3
Captainfab
60-66 Nut
That depends on how you are using your truck. Are you using it like a truck or is it mainly a cruiser? what engine do you have? The 3.42 gears will still give you some decent pulling power. The 3.07's will be better for highway driving, but you will sacrifice some low end pulling ability. Either way, you will need to change the carrier if you have 3.73's or lower.
Old 01-25-2013, 01:30 PM   #4
LVPhotos
LVPhotos's Avatar
http://adamsdriveshaft.com/measurements_chart
Here a gear chart from the guys I use. A 3.73 with a 235/75/15 (28") tire is in the sweet spot. Any higher would improve gas milage. Lower more power. I have 295/45/18 on the rear now 28" with 3.73 posi 12 bolt and it will run all day in fourth. Its the advantage of the 5th gear overdrive to pass gas stations.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-25-2013, 02:01 PM   #5
Lugnutz65
Lugnutz65's Avatar
So it sounds like you have a T5 tranny maybe?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 01-25-2013, 02:21 PM   #6
LVPhotos
LVPhotos's Avatar
Yes indeedee. Though an after thought the T-5 was never intened to use the torque 425+ to the rear. It is however using the factory bellhouse with motor mounts and the side engine mounts which helps the twist. The aluminum housing is its weak point.
Old 01-25-2013, 05:05 PM   #7
61memo
Thanks for the info my 66 suburban is going to be a cruiser.what year diff can I use that i would be able to install 3.42s or 3.08 keep in mind my burban is a six lug bolt pattern thanks once again for you help and my engine is the original 283 v8
Old 01-25-2013, 05:11 PM   #8
61memo
I forgot to add to my thread a diff that i dont have to change the carrier
Old 01-26-2013, 01:57 AM   #9
Captainfab
60-66 Nut
It doesn't have anything to do with the year. You will have to find a '63 to early '70 12 bolt that already has 3.07 gears.
With the 283 not producing much torque, you might be better off with the 3.42 gears. I just am not familar with the 1st gear, gear ratio in those 3 speeds. If you can find a 12 bolt with 3.07's, give it a try and see how well you like it.
Old 01-26-2013, 07:52 AM   #10
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I have a 3.07 in mine running 215/70/15's with a TH350 and wish I had a more taller gear in it. I plan for a taller tire next go round to get more out of it.
Between your tire size and mine, you will lose almost 6 mph just from different tires sizes.
This a tool I use to determine that.
http://www.miata.net/garage/tirecalc.html
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-27-2013, 02:58 PM   #11
61memo
Thank you all for your info as far as finding a 63 to 70 diff with 3.07 s no luck and adding 3.07s to my diff around 800 dlls but there is tons of newer rear diffs six lug bolt pattern that is why I asked. Hey 61 FL APACHE how well do you do on the freeway with your combo on your truck(3.07s and 350 tranny and 215/70/15) thanks once again for your help
Old 01-28-2013, 01:28 AM   #12
Captainfab
60-66 Nut
The '88 and up differentials are going to be about 3" wider than the differential you have now. Plus there will be cutting and welding involved in installing one under your truck
Thread Tools
Display Modes
