Old 01-26-2013, 07:34 PM   #1
adam68
Gas Tank '48.
Newbie here with a '48 3100 5 window. The owner gave me a good condition original fuel tank as he installed one behind the seat.
I want to go back to stock, but all I have is the tank and fill neck. Does anyone have a pic of what the installed tank looks like and/or how the straps mount.
adam68 is offline   Reply With Quote
Old 01-26-2013, 10:21 PM   #2
lazypineapple
lazypineapple's Avatar
Re: Gas Tank '48.
Here ya go
or this
here i made my own cross bars out of square tubing and bought a couple of straps.
lazypineapple is offline   Reply With Quote
Old 01-26-2013, 10:24 PM   #3
adam68
Re: Gas Tank '48.
Old 01-26-2013, 10:26 PM   #4
adam68
Re: Gas Tank '48.
Wow, this.info is unreal. Thanks for the great pics and details. I now have direction.
Thanks again.
Old 01-26-2013, 10:35 PM   #5
lazypineapple
Re: Gas Tank '48.
I did a far amount of research before i came up with my mount on the Cheap.
Factory OEM Hanger mounts are still available, new or used.
Same mount a Panel/Burb uses.
Old 01-26-2013, 10:38 PM   #6
adam68
Smile Re: Gas Tank '48.
I'm going to a big swap meet tomorrow in long beach, so I will look around as there is lots of Chevy stuff there.
Thanks again
Old 01-27-2013, 09:48 AM   #7
crossfire84
crossfire84's Avatar
Re: Gas Tank '48.
Originally Posted by lazypineapple View Post
Here ya go
or this
hey lazy p could you tell me what fuel tank that is? that is a nice setup you have there, thanks for your help.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 01-27-2013, 09:55 AM   #8
lazypineapple
Re: Gas Tank '48.
Got it Chevys of 40s
Link
Old 01-27-2013, 10:13 AM   #9
crossfire84
Re: Gas Tank '48.
Link
thank you!
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 01-27-2013, 10:58 AM   #10
wuss721
Re: Gas Tank '48.
On ur gas tank what sending unit will u be using. I have that same tank in my suburban but can't find one
wuss721 is offline   Reply With Quote
Old 01-27-2013, 07:03 PM   #11
lazypineapple
Re: Gas Tank '48.
i went with this Fuel sender 30ohm unit
Old 01-29-2013, 11:34 PM   #12
adam68
Re: Gas Tank '48.
Follow up question. I have the tank frame mounts. The rear of the two has 3 bolts and has factory holes. The front bracket looks like it doesn't go directly on the inside frme rail.
Is ther a spacer of some sort that holds this one in place between bracket and frame rail.
Old 02-16-2013, 02:59 AM   #13
tttuba
Re: Gas Tank '48.
if you haven't done the tank yet try this thread It is what I used.
http://67-72chevytrucks.com/vboard/s...d.php?t=351887
tttuba is offline   Reply With Quote
Old 02-16-2013, 10:33 AM   #14
adam68
Re: Gas Tank '48.
Good post. After all is said and done, the duals I have on my six will interfere and will do the same should I install a V-8.
So, I'm going to place a mustang tank or other like it under the bed and then remove the inside cab tank and plug the funky hole the former owner made.
When done, I will then list my two stock 47/48 tanks with filler necks and one set of brackets.
Thread Tools
Display Modes
