Old 01-27-2013, 01:28 AM   #1
zicc1835
zicc1835's Avatar
tilt column
pulled this out of my 72 cheyenne today going to clean it up and paint it as i am repainting the interior my question is does it look like OE ,,,I could id the NS switch from another post as correct for truck not van ....the hazzard swith can anyone tell is that correct for 72 the indicator looks funky to me also it has a camaro wheel on it ? i see if i have another pic thanks
jz
zicc1835 is offline   Reply With Quote
Old 01-27-2013, 01:35 AM   #2
zicc1835
zicc1835's Avatar
Re: tilt column
pic
Old 01-27-2013, 01:47 AM   #3
67swb72klb
67swb72klb's Avatar
Re: tilt column
never saw a hazard knob like that on a 72 mabe it was out of a later model van
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 01-27-2013, 02:27 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
Re: tilt column
The hazard switch may have been replaced. The newer ones like this will screw onto to old switch. What is the overall length of your column? That will determine whether or not its a truck or van tilt. I forget the exact dims, but a van tilt is longer and requires collapsing the intermediate shaft.
WIDESIDE72 is offline   Reply With Quote
Old 01-27-2013, 02:29 AM   #5
WIDESIDE72
WIDESIDE72's Avatar
Re: tilt column
Judging from the half round "horseshoe" wiring connector, I am going to go out on a limb and say you have a truck tilt. I believe all of the newer columns had a flat connector. Does anyone know if the "old" van columns also had the "horseshoe" connector?
Old 01-27-2013, 02:37 AM   #6
FirstOwner69
FirstOwner69's Avatar
Re: tilt column
Pictures of the splined end (most positive identifier), the gear selector indicator lens and the levers would be a lot of help. I'm guessing it's a true truck tilt. I've "rescued" 3 of these over the last couple years, and one or 2 had that incorrect knob for the flashers.
Edit: Looked at the pics again. The turn signal and tilt levers are correct for a truck tilt.
FirstOwner69 is offline   Reply With Quote
Old 01-27-2013, 11:00 AM   #7
hugger6933
Re: tilt column
Could be a motor home tilt. They are the same in lenght and are almost the same as the truck tilt key word being almost. The end of the steering shaft is the same the shifter is angled a little differently being not at all on the M/H tilt the nss is in a different placebut can be moved as the slot is in the other place as well. The M/H tilt were able to be had in a lot of P 30 trucks/vans/motor homes multi use type things they used them for through the 1985 model year that I know of because the latest one I have is that model. I am sure at some time or another someone has passed one of these off as a truck tilt either knowingly or unknowingly I think it could be a honest mistake if you were not very familair with the trucks in's and out's
hugger6933 is offline   Reply With Quote
Old 01-29-2013, 01:44 AM   #8
zicc1835
zicc1835's Avatar
Re: tilt column
another pic nubs still present on interm
Old 01-29-2013, 01:45 AM   #9
zicc1835
zicc1835's Avatar
Re: tilt column
nss
Old 01-29-2013, 01:46 AM   #10
zicc1835
zicc1835's Avatar
Re: tilt column
another angle
Old 01-29-2013, 01:49 AM   #11
zicc1835
zicc1835's Avatar
Re: tilt column
last if you need a picture of the spline ill get it tomorrow
thanks to all for all the info
Jz
Old 01-29-2013, 02:55 AM   #12
FirstOwner69
Re: tilt column
So far it looks like the real deal. The shift indicator lens is the truck type. If the splined shaft extends only about 2" from the end of column housing and the arm where the shift linkage attaches is straight (no bends in it), I'd say it's a truck unit. The van column shafts extend about 5" or 6", and the motorhome linkage arm has two 90 degree bends to create about an inch offset. All dimensions are a rough estimate since I don't have any columns here to measure.
Old 01-29-2013, 03:20 AM   #13
zicc1835
zicc1835's Avatar
Re: tilt column
thanks First ill go out there tomorrow and post up some more pics but i think all u have mentioned is what i have ....how about the hazard button!?
Jess
its starting to look like a DUCK makes my day
Old 01-29-2013, 03:29 AM   #14
FirstOwner69
Re: tilt column
It's easy to swap the button if someone wanted to, but more than likely the turn signal switch was replaced, and the replacement came with the newer style button. Very common. I have found 3 truck tilts in the last couple years. I think 2 of them had the same button type as yours.
Old 01-30-2013, 02:05 AM   #15
zicc1835
zicc1835's Avatar
Re: tilt column
just bought a nontilt AT column from Teeitup Randy with a busted haz button (I will try to fix/replace the button)to replace this tilt in my 72 and keep it for the next build i include one more pic and thats it...... I think im beating this horse to death
Old 01-30-2013, 02:11 AM   #16
FirstOwner69
Re: tilt column
Definitely a genuine truck tilt!
Jim
Old 01-30-2013, 09:04 AM   #17
29od1
Re: tilt column
That's a mother trucker!
29od1 is offline   Reply With Quote
Old 01-30-2013, 06:35 PM   #18
zicc1835
zicc1835's Avatar
Re: tilt column
me too thanks
Thread Tools
Display Modes
