Old 01-27-2013, 10:23 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
6.0 LQ4, LS6 Heads, LS2 Cam, Comp Cam, Lots of LS Swap Parts
6.0 LQ4, complete with all accessories and wiring harness, ECM, and sensors (not pictured). Ran before pulled, though I had planned on a rebuild.
SOLD I am willing to crate and ship or hold for pickup for a short time.
I need this gone, it's sitting on my only engine stand!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-27-2013, 10:29 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 6.0 LQ4, LS6 Heads, LS2 Cam, Comp Cam, Lots of LS Swap Parts
799 cylinder heads, these are the same casting as the highly desirable 243/LS6 heads, but without the sodium filled valves. This is the best cathedral port head GM produced. Removed from an 18,000 mile engine. These are bolt-on and go heads. Fully assembled with rocker arms and covers.
SOLD
-Chris
Old 01-27-2013, 10:35 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Comp Cams XR273HR. 220/224, .530/.534, 112 LSA camshaft. Gently used low miles. Great truck cam.
SOLD
-Chris
Old 01-27-2013, 10:39 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
LS2 camshaft and 'yellow' springs. Pulled from a low mile '06 Trailblazer.
SOLD
-Chris
Old 01-27-2013, 10:44 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
LSA oil pan. Includes pickup, dipstick, windage tray, bolts, and gasket. This is a new take-off from a never run engine.
SOLD
-Chris
Old 01-27-2013, 10:56 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Pacesetter ceramic coated long tube headers, 72C2276. These are designed to fit a Trailblazer SS, but should fit our trucks.
SOLD
-Chris
Old 01-27-2013, 10:59 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Edelbrock coil covers. Cast aluminum, brand new in box. Includes all hardware and instructions.
SOLD
-Chris
Old 01-27-2013, 11:05 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Kwik Performance A/C bracket. Mounts Sanden style compressor to LS motor. Designed for truck style accessories.
SOLD
-Chris
Old 01-27-2013, 11:08 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Bowtie Overdrives TV Made EZ bracket and cable to use a 700R4 behind an LS motor.
SOLD
-Chris
Old 01-27-2013, 11:12 PM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
Fel-Pro LS cylinder head bolts. Full set.
SOLD
-Chris
Old 01-27-2013, 11:16 PM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
Coolant temperature sender. Works with stock truck gauge, turned down to fit LS cylinder head.
SOLD
-Chris
Old 01-27-2013, 11:17 PM   #12
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
How many miles on the 6.0?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-27-2013, 11:22 PM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Unknown. It was not original to the truck I pulled it from, which had about 250k on it. I do not know when it was replaced. This was from a '00 truck. It has decent, but not great compression. I had planned on a rebuild.
-Chris
Old 01-27-2013, 11:59 PM   #14
5150
C10 Club Tennessee
5150's Avatar
I'll take the temp sender.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 01-28-2013, 12:16 AM   #15
Nohatch
Pm sent on headers, oil pan and sending unit. thanks
Nohatch is offline   Reply With Quote
Old 01-28-2013, 12:32 AM   #16
Number98
Prestige Worldwide
Number98's Avatar
$150 plus shipping
I will take this if it's still up for grabs..
Number98 is offline   Reply With Quote
Old 01-28-2013, 12:49 AM   #17
gringoloco
A guy with a truck
gringoloco's Avatar
Sending PM for pmt info
PM returned
Nohatch showed interest first, I'll let you know if he passes
-Chris
Old 01-28-2013, 01:04 AM   #18
greens69
greens69's Avatar
Put me in line for the oil pan if it gets this far....
I will take the Kwik bracket if still available.
Houston and Dallas Autorama Show Chairman
///Relaxed Atmosphere
1969 Chevrolet C10
1972 Chevrolet 2WD Blazer
1987 GMC Sierra
greens69 is offline   Reply With Quote
Old 01-28-2013, 01:26 AM   #19
gringoloco
A guy with a truck
gringoloco's Avatar
Pan is pending. Bracket is yours. PM sent.
-Chris
Old 01-28-2013, 07:25 AM   #20
exploderjim
exploderjim's Avatar
I will take the coil covers. Pm me instructions for payment and shipping.
exploderjim is offline   Reply With Quote
Old 01-28-2013, 07:50 AM   #21
jmedero
jmedero's Avatar
Did I miss how much for the heads?
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-28-2013, 08:22 AM   #22
gringoloco
A guy with a truck
gringoloco's Avatar
Pm coming your way
Oops! $250 plus ship
-Chris
Old 01-28-2013, 09:16 AM   #23
1970 C10 MJW
1970 C10 MJW's Avatar
I will take the heads..
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 01-28-2013, 10:14 AM   #24
rmvlt1100
rmvlt1100's Avatar
$100 plus shipping
I'm interest in the coil covers if they haven't sold yet.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 01-28-2013, 10:53 AM   #25
gringoloco
A guy with a truck
gringoloco's Avatar
Clear your PMs, I need a shipping addy for quote
Pending sale. Will let you know if it falls through
-Chris
Thread Tools
Display Modes
