Old 01-31-2013, 06:08 PM   #1
ap2002
Alternator help
I can't seem to find the replacement alternator for my 71c10. Truck has a 454 BB block out of a 89-90 silverado. Here is the kicker, truck has serpentine belt but auto parts can't seem to find a matching alternator for it. Either they find the right alternator with the correct plug but the then the pulley is a v-belt.. The alternator that is on right now is part# 1100264, when I go online it also has a v-belt and not the serpentine pulley. Do y'all think pulley was changed on alternator and that's why I can't find right one? Thanks for the help
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 01-31-2013, 06:15 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Alternator help
Yep, swap the pully
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-31-2013, 06:15 PM   #3
tex_waco_usmc
Project Heaven in my 67!!!
Re: Alternator help
Pop and Swap the pulley between the two alternators!
tex_waco_usmc is offline   Reply With Quote
Old 01-31-2013, 06:31 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: Alternator help
Can you compare with one that has the serpentine belt pulley to see if it's the same? Try NAPA or Carquest if you have one in your area. They seem to have more knowledgeable people that can help you out.
If you already bought it and it has the pressed on pulley, you can rent the tool at Autozone or if you think you will do it again in the future, buy the tool kit for $20-$30.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 01-31-2013, 06:33 PM   #5
ap2002
Re: Alternator help
Ok thanks, I didn't know it was ok to swap pulleys, I'll try that
Old 01-31-2013, 08:03 PM   #6
oklalawnboy
oklalawnboy's Avatar
Re: Alternator help
I have that same set up (88-90) on my 76 Monte (383). I don't remember having to change the pulley as I used everything off the donor truck. But a pulley change should do the trick.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 01-31-2013, 08:36 PM   #7
ap2002
Re: Alternator help
Is there any DIY online? Can't seem to find any
Old 01-31-2013, 08:57 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: Alternator help
Are you referring to the pulley removal? Several years ago, the place I bought an alternator from swapped it out for me. Took them all of about 10 minutes.
If you have an impact wrench it works a lot better if you have one otherwise any shop can do it for you.
06 Trailblazer
Thread Tools
Display Modes
