Old 02-01-2013, 02:52 AM   #1
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
14 10.5" Bolt Locker
Anybody have any experience with Powertrax lockers? I'm looking to install one in my 14 bolt on the 79 to help it out a little bit when conditions deteriorate, and want to make sure it's decent and will hold up.
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 02-01-2013, 08:37 PM   #2
LONGHAIR
Re: 14 10.5" Bolt Locker
Not specifically in a 14bolt, but I have installed a few of them. They go in easily and hold up well. Be aware that it will drive a bit different, especially in wet or snowy weather. Caution anyone that you let drive it about this too.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-02-2013, 10:55 AM   #3
Mike C
Mike C's Avatar
Nothing wrong with the Powertrax and I have 3 LockRights myseld, but as far as full-float 14's go, that's the cheapest Detroit you can get which would make that a no-brainer.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-02-2013, 11:26 AM   #4
jjzepplin
jjzepplin's Avatar
Subscribed. I think mine has a gov-loc and want to get info as well. 1973. Still working good but I heard them called gov-bomb before.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-02-2013, 01:57 PM   #5
LONGHAIR
The ones in the 14 bolt seem to be better than their smaller versions. I have seen them break too, but not nearly as often. Gov-loc
Old 02-02-2013, 02:45 PM   #6
Redcap
They got that name for a reason. Fortunately, the 10.5" 14bolt Detroit is very inexpensive (as far as lockers go) and easy to install.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 02-02-2013, 10:30 PM   #7
snj8198
snj8198's Avatar
And now Yukon offers their Grizzly Locker for less than the Detroit. Side by side they are same design. Stuck one in the rear of mine. It's tough and a snap to install.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 02-03-2013, 06:14 AM   #8
Redcap
Good to know!
Old 02-03-2013, 10:24 AM   #9
Mike C
Mike C's Avatar
I'm pretty sure if you do have a Gov-Bomb in your FF 14 you will need to buy an open case to install any of the drop-in Lockers including the Detroit or Grizzly. Which means changing the case will require you to measure and possibly adjust the backlash on the ring gear as well. It will also require swapping out the carrier bearings which adds a different level of complication to the swap.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-03-2013, 12:16 PM   #10
jjzepplin
jjzepplin's Avatar
You might be right. That thing looks like a cone shaped deal with a screen in two holes of the surface. Weird. Can't see any spider gears or anything.
Old 02-03-2013, 08:25 PM   #11
Mike C
Mike C's Avatar
That's what the open case looks like also BTW. You can't see the spiders just the spider gear shafts. I think the screen thing is what makes me think it's a Gov-Bomb. Give Google Images a shot and you'll see a bunch.
Also head over to Pirate4x4.com and check out the 14 bolt bible.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-04-2013, 09:32 PM   #12
low67chevy
a open carrier will be a 4 pin carrier and a gov loc carrier will be a 3 pin, ive run the loc rite and liked it but for the money go grizzly or detroit.
low67chevy is offline   Reply With Quote
Old 02-07-2013, 03:45 PM   #13
jjzepplin
jjzepplin's Avatar
http://www.drivetrainamerica.com/p-7...px?cagpspn=plaLooking at the pics online, I believe I have the Eaton type posi. Seems pretty tough
Old 02-07-2013, 04:36 PM   #14
jjzepplin
jjzepplin's Avatar
http://www.drivetrainamerica.com/p-7...px?cagpspn=plalooking at the pics online, i believe i have the eaton type posi. Seems pretty tough
gov bomb?
Old 02-08-2013, 08:56 PM   #15
Mike C
Mike C's Avatar
The aftermarket Eaton posi is different from the OEM Eaton Gov-Lok. The Gov-Lok, or Gov-Bomb as it is "affectionately" known uses gears, springs, and flyweights to apply pressure to the clutch packs. It is not truly a "locker" but a limited slip that functions as an open diff most of the team.
If you hammer on it alot and cause the mechanism to attempt to engage, you can strip gear teeth or otherwise cause it to come apart. It "blows up" like a bomb if you will.
Google Images for 14 bolt Gov-Lok and enjoy the carnage. With that said, the 14 bolt version is at least the strongest version. The 12 bolt one pretty much grenades when you look at it funny.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-10-2013, 04:23 AM   #16
Fixwhataintbroke
Enthusiast
Well it seems generally it looks favorable so, I do believe I'll order one up, sure would be nice to abolish the one wheel wonder. 10 year old balding tires + open diff, along with majority of the weight all sitting up front, just doesn't cut it when conditions worsen around here . Would do tires first but for the brand I'm after, I'll stick with a detroit for now
- Cole
Old 02-10-2013, 01:29 PM   #17
low67chevy
good choice you will love it
Old 02-11-2013, 09:16 AM   #18
jjzepplin
jjzepplin's Avatar
So to replace the Gov-Bomb I will need a carrier too? If so would an open carrier be a good choice and just buy the Detroit to go in it?
Thread Tools
Display Modes
