Old 02-02-2013, 05:15 PM   #1
Bhelton
Bhelton's Avatar
Rear axle
What all rear axles has been installed in 2wd 67 c10s
Be another 12 bolt, 9" or any other...pics of others greatly appreciated
Bhelton is offline   Reply With Quote
Old 02-02-2013, 05:56 PM   #2
bricalabro
Re: Rear axle
the older 10 bolts came in a lot of c10's a 12 bolt from that era is common as well. and a little tougher
I installed a 10 bolt posi from a 91 caprice, it replaced the 12 bolt, it has the same size wheel and carrier bearings as the but a larger pinion bearing. it also has the same size ring gear. should be tough enough for most applications.. not sure what kind of power your running
bricalabro is offline   Reply With Quote
Old 02-02-2013, 06:18 PM   #3
Bhelton
Bhelton's Avatar
Re: Rear axle
Well, it's a 06' 6.0L with a th400. Wanna keep it or turn it onto 6 lug
Old 02-02-2013, 06:56 PM   #4
bricalabro
Re: Rear axle
i would think you can just intsall a six lug rear out of a 90's and up pick up/suv.. guess it depends on how much fabrication you want/can do. another issue depending on the year would be the width.
i would use a hd six lug rear. bigger drums or factory disc brakes. probably from a 1500 tahoe or surburban.
Thread Tools
Display Modes
