Old 02-02-2013, 07:40 PM   #1
K5Silverado
Brakes won't lock up
Hello,
Long time viewer and first time poster here. My '87 K5 won't lock the brakes, and as far as I can remember, it hasn't since I've owned it - several years now. Does anyone have a stock, or nearly stock K5 or truck that has brakes that will lock up easily?
I don't have any stopping problems but have always wondered
K5Silverado is offline   Reply With Quote
Old 02-02-2013, 11:54 PM   #2
Gene
Gene's Avatar
Re: Brakes won't lock up
Ive got differentials out of a 91 and as much as ive tried they wont lock up either.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 02-03-2013, 11:51 AM   #3
K5Silverado
Thanks for the reply Gene. I had an '83 2wd long bed truck years ago that would lock up, so I found it odd that this won't.
By the way, I just went through your entire build thread - very nice truck you have built!
Old 02-04-2013, 11:47 AM   #4
BigRed76
BigRed76's Avatar
I've got a '76 K10 with stock brakes all around and if I step on the peddle hard enough it'll lock up the rear brakes...
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-06-2013, 10:42 PM   #5
K5Silverado
Thanks for the reply. That's good to know. I wonder if it has anything to do with truck vs. blazer, weight on rear-end, etc.
Old 02-07-2013, 06:18 PM   #6
OrrieG
OrrieG's Avatar
Stock tires and wheels? Bigger tires and wheels add rotating mass that is harder to stop. I've heard stories of guys lifting and putting big tires on small foreign trucks, then not being able to stop them or destoying the brakes in the process. Assuming front discs, you might look at the adjustment of the rear drum shoes. The front brakes do most of the braking and may limit pedal travel, therefore drum shoe travel (discs are fully engaged before shoe can travel the full distance to stop the rear wheel). If you are really worried about it you can get an adjustable proportioning valve to adjust the front back bias to your liking.
OrrieG is offline   Reply With Quote
Old 02-07-2013, 11:54 PM   #7
K5Silverado
Thanks OrrieG. Funny you should mention the proportioning valve. I just installed a new one, the original one was leaving a small puddle of brake fluid everywhere I parked - bad leak. That's what motivated me to post my original question. I suppose I was expecting the performance of the new valve to help the brakes lock up, but evidently the old original valve performed just fine as there's no difference in performance between the new and the original. No more leaks on driveways luckily with the new one.
I'm running 32" tires on stock 15"x8" ralleys. Slightly bigger than stock but probably not enough to make a differnce. I'll adjust the rear brakes some, but I think I'm ok with how the truck stops. It just kind of struck me as odd that the brakes never really locked up. I'll see how a rear brake adjustment helps.
Thanks!
Old 02-08-2013, 10:31 AM   #8
BigRed76
BigRed76's Avatar
Well mine's running 35's & it'll still lock up the rears, so maybe something isn't right with my brakes
Zach
Old 02-11-2013, 04:03 AM   #9
rpatowers
I had the same problem with my 72 4 x 4. I installed a hydroboost brake system and they will now lock up.
rpatowers is offline   Reply With Quote
Thread Tools
Display Modes
