Tons of questions -- truck finally here, not so much runnin & drivin
Hello all,
So the shipper showed up with my truck today, and while she runs I am not so sure I feel safe drivin... Pictures are below, observations first (questions in post 2). Being as this is the first time I have seen it, problems I notice out of the gate: NO-GO Items:
Other concerns:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ---Cont---
St. Louis, Mo 1969 C10 2011 Dodge Charger R/T (custom) |
Re: Tons of questions -- truck finally here, not so much runnin & drivin
So I bought her for $600, had it shipped to St Louis for $550. Right now I am $1150 into her. I bought it as a daily driver, something I could drive 64 miles round trip to work every day in heavy traffic. I wanted to fix her up over time, but I expected a running and driving car. I expected something that would pass inspection and I could register, not so much.
Should I cut my loses, sell her to someone looking for a more intense project? Or are items 1-3 on the no-go list fixable on a tight budget so she is a driver? 1. Can the steering column be rebuilt? Or are you better off to replace? 2. Chances that brakes get better with a good reverse bleed? 3. Any thoughts on the signal issue? I assume the turn signals are on the same fuse, left works, nothing for right, no dash indicator, no flash front or back. Could it be contacts in the column, and if so will a good cleaning doe the trick?
man you expected alot out of $550.
looks like a decent start to a rebuild. do the basics to the brakes. pull the wheels, check the pads / shoes. bleed the whole system. Steering column would be best to find one in a junk yard, could even do a tilt one out of a van. signals- here's what i did. Changed the fuses and flashers. Then got my dremel out and dremeled the bulb sockets, they were full of rust. Then i spray electrical contact cleaner in the sockets and took a flat blade screw driver and pushed the base of the bulb in and out (it has a spring behind it). If none of that works, go buy a test light and trace wires, not many there.
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana ![]() instagram - @esso_c10 @projectpawpaw |
#4 | |
![]() Thank you for the suggestions, I will follow up on them! Thanks, Jeff
i think its a good looking but if you dont have the time are money to put in it just sell it to some one who can im sure you can part it out on here and get your money back ill buy the front bumper lol
1969 C20 CUSTOM "RUMBLEr" |
I think it looks like a decent foundation to fix as you go.
Hell, just removing all those stickers would make a night and day difference in the appearance. Posted via Mobile Device |
#7 | |
looks like she came with factory air and power steering, which I thought was pretty cool on a 69. Jeff
2Cav. I am about one month into owning a 69 CST C20, and i failed my first inspection. The next day i went and got a volt meter and some wire splices and after about 4 hours the fuses stopped blowing and everything worked. About a week after that the distributor went out, it was down for a few days and very frustrating (i drive mine everyday), but parts are cheap and my labor is even cheaper! I had a few moments when i thought the same thing you are thinking.
My advice would be to track down the electrical issue, and bleed the brakes. Even if you decide to sell it, you will be able to say it runs and drives honestly, and probably make your money back. Also, i've read on here that a good soaking of WD40 will loosen up your gear selector pretty well. Mine wasn't bad, but now its great! |
For the price not a bad truck. Just take it one step at a time, safety stuff first then drive and enjoy it. Get to the other stuff as time and money allow.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Doesn't look like that bad of a deal! I'd do a walk around, make a list of things to do, then start checking them off one at a time. Have fun with it.
![]() Join Date: Sep 2011
I think what you have in it total is probably about right if you had found one that wasn't a friends and family deal. So don't beat yourself up over money.
If something goes wrong and you can't drive it to work the next day, is that a deal breaker? Having been there before, having a project of any sort and having to rely on it to get to work and back is very stressful. If you have a backup car, I would keep the truck and fix it as time and money allow. If you were to purchase a turn-key daily driver, you would have to spend a LOT more than $1150. Unless you are one of the lucky saps I keep reading about here on this forum. ![]()
1971 C20 "Shreck" 1980 C30 dump bed "Ratchett" |
When you get ready to get the stickers off, a heat gun will work wonders. Nice looking start also. It doesn't look like $1000 worth of repairs if you can do the work yourself.
#13 | |
Another thing. People will snicker and tell me I'm wrong here, but I had problems shifting from drive to park. I put some Lucas Transmission fix additive in the tranny, and it went away. Posted via Mobile Device |
#14 |
![]() Join Date: May 2012
looks like you have a good start..fix all the important stuff now , and fix it up a little at a time, at least you will have a safe daily driver, and a cool 69 c-10.
#15 |
![]() Join Date: May 2001
Try some WD-40 (or whatever spray you have) and spray down in the column where the shift arm goes into it. It might take a good soaking. Keep working it and it should get better.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
#16 |
I am a Referee of life.
I think you're ok $$ wise.I do think you're overpricing basic repairs.Lube the column,bleed the brakes and tackle the elect.Once those are done (and the PS hooked back up),you should have a driver.I suspect the PS box is leaking since it's not hooked up.Just grab a later box and bolt it in.You'll need a pitman arm puller for that.Don't sweat the air,it doesn't look like a priority right now.Safety stuff first.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#17 |
Cluster King
![]() Join Date: Nov 2012
I agree with all of the above. work on the safety issues first. The oil leaks can be fixed a little at a time and still allow driving. Do some cosmetic work in between will add some inspiration. Give it a good scrubbing inside and out, paint the rims and rear bumper and have some fun.
#18 | |
#19 |
![]() Join Date: Mar 2011
First off, I understand your disappointment, but with that said, you still have a very good project truck--for a decent price. Youre into it for $1150?, really thats nothing--usually 1150 will get you a Real junker.
I think that your brake issues could be fixed for a couple hundred. A used column is less than $100. The blinker issues are aggravating but could prob. be fixed for less than $50. Thats about $1500 including shipping. Not bad for a driver project. I really wish you good luck with your truck, as I said I understand disappointment--mine disappointed me too-----and I even did a good(?) inspection before I bought it (for a lot more money). It will take some dollars, some bad language, some skinned knuckles and some head scratching----but in the end youll be proud of the result. Again, good luck on your project.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
#20 |
Oh Yeah, I forgot to mention----- even though you have a good project----If I had a friend who lied to me the way yours must have-----I think Id kick his butt then write him off the fiend list forever!!
#21 |
#22 |
The Older Generation
Personally I think you got a good deal. The chances of getting a truck for 1100 bucks NOT including shipping, that would pass inspection would be slim to none... - On the shifter, put the lever in neutral (apply parking brake or block wheels first) and spray some PB Blaster or some other penetrating oil (not WD-40) into the hole that the shift lever goes into on the column. Then pull the lever up toward you and push it back down toward the dash 4 or 5 times to loosen it up. The lever has to move up and down easily to shift gears. After you have done that spray the tube and levers good at the bottom of the steering column then go in and pull the lever up and down again. See if that makes a difference. A lot of people don't realize that you have to pull the shift lever up toward you to shift in and out of certain gear positions. The best way to get help is to post about one problem at a time and get it corrected, then move on to the next one. I don't see a big problem in getting these things corrected if you take your time. LockDoc
#23 |
Thanks for the input all!!! very much appreciated. I did start off a little bummed, but I think everyone is right. I am going to put some work in, see what I can do. If I can knock out these safety issues I still have what I want. I am no mechanic, but I am not opposed to putting in some wrench time. Hopefully I can fix some of this on my own and get her into driver status!
Thanks again all! Expect more questions soon, although I promise I will try search before I ask. Jeff
#24 |
get a container put a quart of auto tranny fluid and a couple quarts of kerosene in get a squirt squirt spray bottle and as you go thru truck remember that parts that move like to b cleaned and lubricated for proper operation
#25 |
In terms of the issue with the blinkers. Replace both flashers in the fuse box. Also, look out for a grounding issue with the front turn signals. The case of the lamp assembly must ground to the grille and over the years it can lose its ground. Similar problems happened to my truck and it drove me nuts until I did some testing!
Gary Slowly looking for my next 67-72 truck |
Thread Tools | |
Display Modes | |
