Old 02-04-2013, 02:32 PM   #1
Chvy2NV
67 5 LUG conversion kit ?
Looking at converting my 67 over to 5 lug so I can start ordering my brakes and wheels but just not sure what i need exactly. I dont want to end up with extra parts.. Thanks !!
Chvy2NV is offline   Reply With Quote
Old 02-04-2013, 05:32 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: 67 5 LUG conversion kit ?
As far as parts, you need a set of five lug conversion axles, axle seals, and a differential cover gasket. Swapping them out is pretty straight forward and not very difficult.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-04-2013, 09:54 PM   #3
Chvy2NV
up^^^
Old 02-04-2013, 10:00 PM   #4
Tim Christian
Tim Christian's Avatar
What kind of brakes are you wanting to order? Are you going to lower it also? Need more info???
Tim Christian is offline   Reply With Quote
Old 02-04-2013, 10:01 PM   #5
jocko
jocko's Avatar
cpp sells a conversion kit if you want to go with all new stuff: http://www.classicperform.com/Store/...k/6569RACK.htm
Old 02-04-2013, 10:35 PM   #6
AustinScott
AustinScott's Avatar
check out my build thread. My 12 year old son and I swapped out our 68 rear axels.. pretty simple swap.
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
Old 02-05-2013, 09:45 AM   #7
Chvy2NV
Going with Wilwood brakes all around. The truck is static lowered now 3/5. Will be lowering it more. Still not sure if I'm going to lay frame or not.
Old 02-05-2013, 11:00 PM   #8
Square_78
Square_78's Avatar
From what I understand, most disc brake drop spindles push the wheel out. CPP says 1/8" but some other drop spindles move the wheels as much as 3/4" outward. CPP makes a "modular" spindle that actually keeps the wheel tucked in or further in than stock. Just something to think about so you make sure your wheels dont rub on the fenders.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 02-06-2013, 12:26 AM   #9
1967chevytruckguy
you can have your axles redrilled for dirt cheap ! hudlow axle in tennessee does them for 150 for both and their number is 423 362 3006
1967chevytruckguy is offline   Reply With Quote
Old 02-06-2013, 09:16 AM   #10
biohazardbill
Not to hijack this but I have a similiar question, I plan on converting rear to 5 on 5 however plan on keeping the drums in the rear. What drums would I need to purchase and would I also need to change the backing plates?
biohazardbill is offline   Reply With Quote
Old 02-06-2013, 01:20 PM   #11
1967chevytruckguy
you can have your axles and drums redrilled for 150 in tennessee at hudlow and they are done right !
Old 02-06-2013, 02:10 PM   #12
Chvy2NV
Can't seem to find it on the website to check the pricing.
Thread Tools
Display Modes
