Old 02-04-2013, 03:23 PM   #1
Wadewells
Throttle arm question
I have a 65 c-10 with a 350, Holley yadda yadda...
When I adjust my carburetor linkage to open fully the pedal sits too high and won't allow the carburetor to return to idle.
When I adjust the throttle linkage so the pedal is a comfortable position, the carburetor won't open but about 2/3 the way open.
Is there different lengths of throttle arms?
Wadewells is offline   Reply With Quote
Old 02-04-2013, 05:15 PM   #2
Wrenchbender Ret
Re: Throttle arm question
Can you move the linkage rod closer to the center of the throttle shaft? that will give it a longer stroke.
Wrenchbender Ret is offline   Reply With Quote
Old 02-04-2013, 05:40 PM   #3
64fleetside
V8s used a taller accelerator arm at the firewall-you prolly have a six cylinder throttle arm.
64fleetside is offline   Reply With Quote
Old 02-04-2013, 07:27 PM   #4
brokenspoke
brokenspoke's Avatar
^^^^^what he said^^^^^^
brokenspoke is offline   Reply With Quote
Old 02-04-2013, 08:33 PM   #5
Wadewells
I thought that might be problem.
Yes, the truck was originally a six.
Does someone out there have one they could possibly photo and/or measure??
Thanks!
Old 02-07-2013, 11:47 PM   #6
Wadewells
Thanks!
Anyone?????
Old 02-08-2013, 12:06 AM   #7
losthope
losthope's Avatar
you can extend yours with a little modifacation , look in my build thread link at the bottom of this post and you can see how i did mine...
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 02-08-2013, 12:09 AM   #8
losthope
losthope's Avatar
post #65 on page 3 of my build thread...
Timmy D.
Old 02-08-2013, 12:14 AM   #9
travz500
travz500's Avatar
Anyone?????
send me a PM i can help you out I think
travz500 is offline   Reply With Quote
Old 02-08-2013, 12:38 AM   #10
travz500
travz500's Avatar
Wade i tried to reply to your PM but it wont let me says you dont have your account setup to receive them or cant receive them
Old 02-11-2013, 01:22 AM   #11
Wadewells
Thanks!
*crickets*
Anyone else?
Old 02-20-2013, 12:40 PM   #12
Wadewells
Added 2" to the throttle arm, pedal feels comfortable, opens fully when "matted" and returns to idle.
Thanks to those with good intentions!
Old 02-21-2013, 12:18 PM   #13
earl84
Hey, wade wells, I don't suppose you could snap a few photos of your modification and the throttle rod and linkage setup all the way from the firewall to the carb, could you. I am having the same sort of issue and the PO seriously had just about everything rigged up as poorly and cheaply as humanly possible.
earl84 is offline   Reply With Quote
Old 02-21-2013, 01:27 PM   #14
Wadewells
Sure, glad to;
Old 02-22-2013, 11:06 AM   #15
earl84
Thanks, that helps a lot.
Thread Tools
Display Modes
