Old 02-05-2013, 09:45 PM   #1
yossarian19
Fuel filter adapter / line connection ??
OK.
Short story: Is it safe / wise to use rubber fuel hose on a barbed fitting, or does it need a smooth fitting to seal properly?
Long story: So I'm running 3/8" Dorman nylon fuel line.
Somehow I wound up with a 02 Camaro LSI filter.
I know about the C5 part but it isn't a good match to my motor since I have a rail mounted pressure regulator & return nipple.
The Camaro filter has a male quick connect & a 14x1.5 O ring female fitting.
I got a Dorman piece that has the appropriate male fitting but the other end of it is smooth, as for rubber hose.
Can i get away with running a 3/8" barb fiting in the nylon line & a short length of rubber fuel hose between the other side of the barb fitting & the piece going to the filter?
Really, I don't care if I replace the Camaro filter with something else - just as long as I can plumb it in without too much heartache or money spent on oddball fittings.
yossarian19 is offline   Reply With Quote
Old 02-06-2013, 01:48 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fuel filter adapter / line connection ??
Why are you bothering to use that filter if your running a return system? Wouldn't you pretty much eliminate the whole headache by just running a universal FI rated filter?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-06-2013, 03:14 AM   #3
yossarian19
The Camaro LS1 filter is a standard style, 3/8 quick connect / 14x1.5 female o ring fitting fuel filter. Speced for use in a system running 54-62 lbs. This is the one I plan on using.
The Corvette filter has the integrated regulator. I'm not using that one.
The "truck" filter looks like dual 14x1.5 female threads, which I could use but won't since it won't make my life any easier.
The Trailblazer filter is spec'ed for a lower-pressure system, 48 to 54 lbs, but I suspect it could work just fine in an LS swap. It uses quick connect fittings on both ends. I think, though, that I'll just stick with the native parts for LS V8 engines.
In any event, I'm going to just put 2 hose clamps on each end of as short a piece of rubber hose as I can make it & call it a day, plumb some fuel & move on with life.
Old 02-06-2013, 11:48 AM   #4
ls1nova71
ls1nova71's Avatar
You can put FUEL INJECTION hose on a barb fitting and clamp it with fuel injection clamps and it will work fine. On the other end, if it's a piece of steel tube, you can put the first step of a double flare on the end using a flaring tool and it will put a 'bubble' on the end and then you can clamp it (I usually use two clamps on them, with the screw parts opposite of each other) and it will work.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Thread Tools
Display Modes
