Turns further left than right
My 72 GMC 4X4 has a 4" lift from the previous owner, they set it up to turn way more to the left than the right. It's a pain in a tight parking lot. I'm pretty sure I need to simply adjust the drag link but was curious if I should set it up to turn equaly in each direction or are they supposed to turn more in one direction?
http://smg.photobucket.com/albums/v655/aaronhero/ |
#2 | |
Re: Turns further left than right
It should be basically equal. When the steering wheel is "centered"there will be the same amount of turns in each direction. As far as practical application, you will find that in most street driving, you turn sharper to the right. A left hand turn crosses another lane, making a wider turn.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
![]() Join Date: Mar 2003
Sounds like you need to adjust (lengthen) the drag link. Is the steering wheel straight going down the road?
#4 | |
Turn steering wheel all the way in one direction. Turn it the completely the other way counting the turns as you go. Now center the box going back again 1/2 the amount of turns. This will be where the steering wheel needs to be put back on straight. Drive down the road to see where the steering wheel sits while driving straight, make some sort of reference. Turn drag link...lengthening...until steering wheel is where it is supposed to be. Test drive again
![]() Join Date: Feb 2013
I bet it has a bunch of bump steer too. kwmech is right. drag link. I'm not sure how a 72 is set up but on a 73-87 if you don't have a drop pitman arm, or a stepped drag link, the truck will do just the opposite of yours. If your drag link is at an angle, it will cause the truck not to turn one way or the other. You can articulate a 73-87 to a point where it won't turn at all. That is why people put cross over steering on them.
#7 | |
Hmmm, have you taken it to a good alingment shop? It could be miss alinged. Or there is something wrong with the steering gear box. I not to sure now.
#9 | |
good to know mine needs some adjustment also not too bad but noticible when parking
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#11 | |
this is extremely common in old lifted chevys lol i think every single one i have ever been in has this problem surprisingly my suburban didn't have that problem but when i put in a d60 i lost a bunch of turning which is upsetting because before it was pretty good
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#13 | |
#14 |
Guys.
Just learned that the probable cause is your pitman arm is installed to the wrong splines on the steering box. |
#15 |
![]() Join Date: Aug 2008
That shouldn't be possible if unless the output shaft and pitman arm have been modified. Simply lengthen the drag link. Should take about 30 minutes to get it close to centered.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#16 |
I had the same problem as the OP's truck. I had to center the box, then adjust the stops (on the knuckles) to center the linkage. Than I was able to set the toe and center the steering wheel.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#17 |
Glad this came back after a year and a half
#18 |
I think BigDav is right. I had to first disconnect the pitman arm, and center the drag link, center the box then reconnect the pitman arm.
Thread Tools | |
Display Modes | |
