Old 02-14-2013, 09:02 PM   #1
Baldeagle SR
s10 frame and running gear
Has anyone put an s10 frame and all running gear under a 56 chevy pu. Thanks Rich
Baldeagle SR is offline   Reply With Quote
Old 02-18-2013, 06:06 AM   #2
andrewmp6
Re: s10 frame and running gear
I'm sure people have done it if your looking for a kit no one makes it for a s10 frame.But there is a frame swap kits for a gm b body and 73-87 gm pickup frame http://www.e-zchassisswaps.com/1955.htm
andrewmp6 is offline   Reply With Quote
Old 02-18-2013, 08:29 PM   #3
Baldeagle SR
Thanks Andrew good info on that site. Rich
Old 02-19-2013, 03:36 AM   #4
andrewmp6
Are you trying to a build a 4x4 truck?
Old 02-19-2013, 09:31 AM   #5
Baldeagle SR
I haven't decided yet. But if I do I want to go with an indepent sus. Rich
Old 02-20-2013, 07:33 AM   #6
andrewmp6
I did some digging a found some guys used the 88-98 truck frame http://67-72chevytrucks.com/vboard/s...d.php?t=427550
Old 02-20-2013, 11:37 AM   #7
Baldeagle SR
Looks like several options. Thanks for the link. Rich
Old 02-21-2013, 02:23 AM   #8
andrewmp6
Its not a bolt in but i would trust a 1/2 ton frame and drive train over a s10s.And the 88-98 will give you you the ifs 4x4 you want also.
Old 02-21-2013, 11:48 AM   #9
Redcap
S10 running gear is weak under an S10, let alone a fullsize truck.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 02-21-2013, 12:19 PM   #10
Baldeagle SR
Thanks Guys I appreciate the info. I have been in the closet for the last 20 years. Rich
Old 02-22-2013, 03:53 AM   #11
andrewmp6
He has a point most off road s10s i have seen run full size truck axles.
Old 02-22-2013, 11:38 PM   #12
waybad
waybad's Avatar
the track width is better for a 4x4 with the s10,, but they are weaker, I'm going with the s10 4x4 when I swap over,, the front track width is almost the same as stock..but if you want ifs and not 4x4,, just do the mustangII..frams are about the same width also..good luck
waybad is offline   Reply With Quote
Thread Tools
Display Modes
