02-17-2013, 09:40 AM | #1 |
Help I can't turn right!!
Hey everyone I have a big problem and I need to see if anyone has gone through this issue before with their project. I have full turning to my left and everything is good there but i only get an inch or two to the right front center. Anyone know a possible fix to this problem? I've taken the linkage apart and aligned everything and it did not make a change in it at all. I will post pictures of the set-up later today when i get out to the truck. I have never owned a lifted truck before and so this is all new to me with the lift kits and all. Someone please help.
Scott And Jessica 2002 GMC Yukon XL 1985 K20 Chevy Suburban 2005 Chevy 2500 HD W/T |
02-17-2013, 09:44 AM | #2 |
Re: Help I can't turn right!!
Did you buy this truck this way or did you lift it?
Lifted solid axle trucks require steering correction if the lift is over 4", and sometimes 4" or less to correct geometry. Depending on the lift, the steering arm can be rotated quite a bit one way for the drag link to reach the knuckle. This has the effect you describe of reducing turning in one direction.
02-17-2013, 01:00 PM | #3 |
Ok I had this happen to me and it was a dumba$$ attack. When I hooked the steering stabalizer up, I had it wrong. I started with the wheels centered, and the stabalizer in the "closed" position. The stabalizer would "open" up turning left, but when I truned back to center, it would "close" all the way, not allowing me to turn any farther to the right. It was a simple fix. Hope this helps.
1969 4x4 Nothing beats a good rock drill and some dynamite |
02-17-2013, 04:09 PM | #4 | |
Sounds like someone did the minimum when installing the lift kit. You really need either a dropped pitman arm or raised steering arm to get it corrected.
As temporary help, you can adjust the drag-link to be longer. This will give you some right turn back, but it is not a permanent cure. The angle of the joints on the ends of the drag-link is too extreme, especially to the right.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
02-17-2013, 04:16 PM | #5 |
left only huh... you could always join NASCAR!
seriously though, might want to check the stabilizer and make sure the drag link (steering box to wheel) is horizontal... might need adjusted.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-18-2013, 10:52 AM | #6 | |
02-18-2013, 11:27 AM | #7 |
time for crossover steering...
probably not necessary but it would be an upgrade with that much lift
02-18-2013, 08:59 PM | #8 | |
You could have lead with the 10-12 inch lift thing...
Yeah, we are going to need pics to see what has been done, or not done? I'm with msgross on this, it really would be best to go with cross-over steering.
02-19-2013, 09:45 AM | #9 |
02-19-2013, 09:50 AM | #10 | |
02-19-2013, 05:49 PM | #11 |
Here are the pics of the steering linkage. Hopefully this helps everyone give me some insight as to how to fix this problem.
02-19-2013, 09:10 PM | #12 | |
Ok, looks like a raised steering arm and a dropped drag link. The angle isn't that bad, so it just needs to be lengthened, if it can be? Be careful about the amount of thread contact when you unscrew the ends. It may not be able to go as far as you need. At that point you are going to either replace it or step-up to cross-over.
02-19-2013, 09:21 PM | #13 | |
02-20-2013, 01:45 AM | #14 |
i would highly suggest going to cross over steering and i would say that your truck has atleast an 8 inch lift if not 10 inches
02-20-2013, 01:21 PM | #15 |
With a 4" lift, that raised steering arm should be in line with the pitman arm. Figure whatever the drop on the drag link is plus the 4" of the raised steering arm is the amount of lift on the truck.
02-20-2013, 02:21 PM | #16 |
You have mixed matched parts that don't go together, and for a 10" to 12" lift I would say a 12"
1. Your S drag link has the wrong end and looks to be welded to the s drop.They had don that because the stock rod end would reach ( still needed a steering block under arm or drop pitman arm. No matter what the steering is never going to be good with that. The only way to have steering as said above is crossover.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
Thread Tools | |
Display Modes | |
