Old 02-19-2013, 05:05 PM   #1
BrookelynnGreen
BrookelynnGreen's Avatar
Rear Differential Problem 86 C10
Yesterday I replaced the differential gasket & oil. This morning I had 3-5 small drips on the ground. I put sand over the spots and went to work, came back and parked in same spot. Checked on it about an hour later and there were 2-3 spots. Nothing major. What should I do? Jack up truck and see if i can tighten the bolts more? Redo the gasket & fluid? Please help. Thanks in advance!!
PS. When i look at the differential I do not see any dripping coming down. So I dont know if its residue drips or something coming off the differential because its hot. i don't know. im a little frustrated because i always get this stuff right!!
-Samuel
"Knowledge Is Power"
BrookelynnGreen is offline   Reply With Quote
Old 02-19-2013, 09:52 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Rear Differential Problem 86 C10
If there are drips you should see where it is coming from. Get a can of brake clean and clean it off, Go for a drive and see if it still is leaking when you get back. Hopefully you scraped all the old gasket off the housing and diff cover?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Thread Tools
Display Modes
