Old 02-19-2013, 06:30 PM   #1
rs74
rs74's Avatar
K30 questions
Would my 84 K30 C&C front and rear with duals fit directly if I were to put them into an 86 K30 SRW 4x4 pickup? I found an 86 for sale that is SRW and I have the dual setup waiting for a truck. The front end should go in with no issues I think but didn't know since the rear end was C&C with duals. Are the perches the same widths between the two rearend.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-19-2013, 07:21 PM   #2
meatwagon83
meatwagon83's Avatar
Re: K30 questions
no, the front requires different hubs and the rear is different, but the c&c rear will bolt up but if the truck doesnt have any lift on it the tires will hit the bed
meatwagon83 is offline   Reply With Quote
Old 02-19-2013, 07:27 PM   #3
rs74
rs74's Avatar
Re: K30 questions
The Dana 60 out of my C&C is complete. I would think i could unbolt it and switch it over. I would plan on running a flat bed so that wouldn't be an issue. I should have stated that before sorry.
Roy
1987 R10 shortie
Old 02-19-2013, 07:34 PM   #4
83GMCK2500
Re: K30 questions
As far as "bolt-in", yes. All of the 1-tons had the same perch spacing, even the C&C. So yes, the D60F will bolt right in, and the C&C axle will bolt right in.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 02-19-2013, 09:02 PM   #5
rs74
rs74's Avatar
Re: K30 questions
Thanks. I thought they would but wanted to be sure. I have been trying to find a regular cab dual rear wheeled K30 for some time around here and this is the closest I can get to it. I came to the conclusion that I might have to just buy a SRW K30 and convert it over.
Roy
1987 R10 shortie
Old 02-19-2013, 09:08 PM   #6
Wrecked1982
Wrecked1982's Avatar
Re: K30 questions
c&c k35 are pretty rare i had to buy a srw 4x4 and do the same you are planning
Wrecked1982 is offline   Reply With Quote
Thread Tools
Display Modes
