Old 02-22-2013, 03:01 PM   #1
restorationboy14
Can someone please tell me how to replace a 3 speed transmission and clutch?
I have a 69 GMC pickup and it needs the tranny replaced. I really need to know how. So if someone could post a step by step process thatd be very helpful! Thanks!
restorationboy14 is offline   Reply With Quote
Old 02-22-2013, 03:56 PM   #2
restorationboy14
Re: Can someone please tell me how to replace a 3 speed transmission and clutch?
Its a 292 3 speed. Thanks!
Old 02-22-2013, 04:07 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
A good service manual breaks it down step by step. Haynes or Chilton...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-22-2013, 04:14 PM   #4
Wrenchbender Ret
You realy need a manual but i'll help you through it. Remove the drive shaft at the rear end & slide it out of the trans. It a good idea to drain the trans. unless you want a puddle of grease in your lap. Remove the clips that hold the shift rods to the trans. Tie the rods out of the way. Remove the pan under the clutch & remove the lower trans mount bolts. They go in from the front. Remove the upper trans bolts from the top of the trans. If you are a pretty stought fella or otherwise in good physical shape you can slide it out & put it on the ground. It weighs about 75 lbs. To remove the clutch, remove the bolts assesable & turn the engine & remove the bolts as they come down. Slide the clutch out the bottom. You may have to push the disc up into the houseing & pull the pressure plate out first.
Wrenchbender Ret is offline   Reply With Quote
Old 02-22-2013, 05:27 PM   #5
cdowns
cdowns's Avatar
reprints of GM factory service manuals are a great cheap investment and a good way to do things right the first time// they pay for thierselves with one job done correctly the first time
most vendors here have them cheap or you can surf ebay for a cheap one too
Old 02-22-2013, 05:30 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
One more thing,many of these trucks have a two piece driveline.You may have a center"carrier bearing" that needs to be unbolted.You will also need to use and alignment tool to install the new clutch.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-22-2013, 05:43 PM   #7
GASoline71
GASoline71's Avatar
Yup... I figure if someone is asking for a major component to be removed, they need to have the right tools and literature to help do it right. It's not like we're pulling an alternator here. Don't even know if the OP has a jack or jack stands.
My advice would be to find a buddy or two that have some wrenchin' skills and ask them for help. I know everybody needs to learn sometime... but it's better with help on a major part like a transmission and bellhousing.
Gary
Old 02-22-2013, 08:50 PM   #8
restorationboy14
I have a haynes 420 manual i didnt find how to do this.
Thread Tools
Display Modes
