Old 02-23-2013, 11:36 PM   #1
elks
Pics of Larger Tanks!!
So my 72 has a 16 gallon tank in it. I am wanting it to be bigger. I now NWMP makes a 37 gallon, but I am very concerned about departure angles.
So can anyone post pics of how their tank hangs. Especially from the rear?
Confidence is the feeling we have before we fully comprehend the situation
elks is offline   Reply With Quote
Old 02-24-2013, 12:43 PM   #2
OldCreek
OldCreek's Avatar
Re: Pics of Larger Tanks!!
Here's my pics of the K5 with the 25 gallon tank. K5 has a 4" spring lift. I had to move the rear crossmember all the way to the end of the frame. The front barely sits behind the pumpkin.
I can't remember if the 37 gallon tank is longer and interferes with the pumpkin or if the volume is made up in height....
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-24-2013, 06:47 PM   #3
Firebirdjones
I run the NWMP 37 gallon in mine, nice piece. Fits nicely and doesn't hang all that low in my opinion, and actually has a kick up in the rear for added ground clearance.
Never any issues with mine off roading and I'm stock ride height. If you are raised at all I wouldn't even worry about it.
Firebirdjones is offline   Reply With Quote
Old 02-24-2013, 09:52 PM   #4
Dale99
I have a 91 30gal. I removed the rear cross member and made my own from 2"sq tubing. It hangs fairly low but I have not drug it yet with a 4" lift.
Dale99 is offline   Reply With Quote
Old 02-27-2013, 11:49 PM   #5
jonesky2
jonesky2's Avatar
pictures please. mostly cross member, pumpkin interference, and how low it hangs thanks.
jonesky2 is offline   Reply With Quote
Old 02-28-2013, 07:10 PM   #6
Dale99
ok, did the best I could. Cant read my yard stick in the pictures. With 33 tires, 4 lift, on stock worn out suspension. The bottom of my tank is at 19.5.
The way I positioned my tank, it comes damn close to the pumpkin, but still clears.
Old 03-01-2013, 06:42 PM   #7
cleszkie
cleszkie's Avatar
When positioning your tank, it should be noted that the rear axle moves to the rear when the springs are compresses (fixed spring eye up front and shackle hanger in rear). So account for some axle movement or your tank will hit the axle center section under compression even if it looks like it should clear at normal ride height.
cleszkie is offline   Reply With Quote
Thread Tools
Display Modes
